20 Most Recent Dell (1Y414) DVD+RW Burner Questions & Answers
Sounds like an issue with the drive. Is your computer still under warranty? If so then I would call dell and get it replaced. If not, then I would replace it myself.
Dell (1Y414)... | Answered on Jan 14, 2009
ask dell only dell can fix dell BIOS passwords
800 hits at dell
https://www.dell.com/community/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&filter=location&location=category:English&q=Dell%20latitude%202120%20password
old dells, very old if you can get in to BIOS
using the F2 key, power on , hammer f2.
then in bios screens see a reset for passwards.
my old D520 had that. but latter the did not allow that for security reasons, but do look first.
ask them first. 11 years old today,, time for RTC coin cell battery.
some PCs with the COIN cell dead go to lockup in PASSWORD.
there are 7 levels of PASSwords
BIOS has 2,
HDD passwords. (doomed)
windows login passwords, many.
email, online, and more.
tell which screen fails, first. there is no other way, but to tell the help what the screen shows exactly or a photo of it failing
Dell Computers &... | Answered 7 hours ago
Your message does not qualify as a question or query for a problem, try somewhere else
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
Dell Computers &... | Answered 3 days ago
1st convert AVI files to MPEG2, use a good converter....
use WINAVI 9...
use a codec called FFDSHOW....
use Nero (Nero Vision) to burn DVD...it will take some time...to burn...
i bet your will never fail .
or
just
add the AVI file in Nero(Vision...make movie option/ Export option / Configure option...) and let it convert to MPEG2 first....
then use the Make DVD option in Nero Vision and then make your menu etc and Burn
Dell Computers &... | Answered on Sep 18, 2019
this is fully covered, at dell.com an even asked and answered 1000 of times.
no PC stated btw. just Dell. (decades of models)
bad RAM memory
https://www.dell.com/community/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&filter=location&location=category:English&q=2000-0123
Dell Computers &... | Answered on Sep 16, 2019
no PC stated, which windows,10?
click win key
see shutdown, and on the arrow on right of that click
switch user
bingo (best I can do, no sure what you are doing in FB at all)
is it dell scanner or what? this normally because of the device get locks, try to cold reset the device.
did you ask dell first on their forum. be best,
what does find mean? the jack, or the driver or both.?
there is no led in any headphone jack that is analog out, not SPDIF. (for sure) the book even tells you that.
im reading your manual now at dell, and there is no such port.
on this PC.
Dell Computers &... | Answered on Sep 14, 2019
I plug and play fails only getting driver for this maker, will work.
are you in the UK,,, we are USA< and when I google that maker it lands UK , why? IDK.
the A79LH , is that you model not stated?
is it USB connected? If not say what?
not is one old and rare scanner my guess over 10 years old.
and w10 does go beyond that for sure if maker stops support and their web page has zero legacy support.
there are generic scanner software apps you can buy and might work.
https://www.winsite.com/generic/generic+twain+scanner/
I would try to contact the maker, find them and contact them.
it's a dell communication support software
1. login as an administrator
2. uninstall the software
The software is only for register the product with dell, no issue u can uninstall
Dell Computers &... | Answered on Sep 13, 2019
1.Its a power connector issue or charging IC issue. give it to the service center they will fix don't do anything.
1. Celeron processor
2. Pentium d
3. Pentium 4
4. Pentium 4 extreme
this processor will support
1. u have express service code from that u will get service tag
2. enter wrong passwords 3 times there u will get one number
3. go to https://bios-pw.org/ and enter that number
u will get one code
4. code u should enter in password column
clearing the BIOS password (not HDD PW)
I will ASSUME its BIOS ADMIN PW locked out. lost PW.
you only said clear but did not say lost the word lost, means
clearing the old (one must know the old first to clear in on most PCs)
is done 4 ways, 4 generations of PC, the newer the harder.
did you RTM first at DELL D630?
your PC is 10years old, so that may be easy, IDK ,lets find out.
Support for Latitude D630 ATG, came with nasty XP OS.
rule 1, in this PC if you turned on TPM chip inside BIOS
that means the PW is locked out to hackers. ok?
if yes then the PC can only be unlocked by DELL.com
we are not Dell.com so can't fix that, why ask here and not dell first is odd.
The PC new has this turned off, so others must have turned this on. fact 1.
fact2: page 71 in your users guide dell.com
If you forget any of your passwords, contact Dell (see "Contacting Dell" on page 152). For your
protection, Dell technical support staff will ask you for proof of your identity to ensure that only an
authorized person can use the computer.
if you can;'t prove you own this PC to DELL that leaves what.
HACKING.
Here is one hacker,(not an endorsement its, desperation)
http://dell-latitude-d630-bios-password.biosremoval.com/
here is the Desperado pages.,
https://www.youtube.com/results?search_query=dell+d630+password
see all those, most will be what I call SCALPERS.
take your $20 and it fails, and no money back.
OK, that is what you get for not writing it down.
some of the youtube posts are inane.
wrong PC,
worse is bios is now dead, with admin locked you can not boot windows, you can not F2 or F12 hot key the BIOS and BIOS
is 100% locked out. so all those videos are silly as are the PC with he HDD lockout, or TPM chip locked. and more there are smart card locks outs and more, so why not ask at Dell.com first.
Dell Computers &... | Answered on Sep 11, 2019
turn off USB sleep in control panel settings
the charge performance will never be as good as $1
AC to USB adaptor, buy one, go whole hog/?
Dell Computers &... | Answered on Sep 06, 2019
no real question asked. no context for sure. if the PC fails to charge the battery is bad 99% of time. if the PC run perfect on AC pack with not battery present, the battery is bad. if batter fails to run the PC with NO AC power. always have 2 batteries, they fail easy if you must have batteries, have 2. some folks just run on AC all the time. learn that the charger is not genius level. it will be fooled by a bad battery so very easy. some batteries seem ok but have 1/10 left capacity the charger does no understand that. and acts odd.
Dell Computers &... | Answered on Aug 27, 2019
Dell (1Y414) DVD+RW Burner Logo
1 questions posted
Ekse
Clive
Clive
View Most Popular
  • Dell Computers & Internet
Most Popular Question
cd burner
  • Computers & Internet
