20 Most Recent Dell Inspiron 2500 Notebook Questions & Answers
stolen laptop?
go to the manufacturer's site, get unlock code based on the model and serial number
Dell Inspiron... | Answered on Apr 05, 2013
go into safe mode and just uninstall your graphic drivers and start again normaly
Dell Inspiron... | Answered on Jan 10, 2013
First download this software,you can try the trial version and install it in ANY computer
http://www.passwordunlocker.com/windows-password-recovery.html
burn a bootable CD or Flash drive
boot your locked computer from CD/DVD or USB
Remove administrator password with the burned CD/DVD or USB flash drive
Dell Inspiron... | Answered on Aug 28, 2012
You might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below......
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Dell Inspiron... | Answered on Jul 11, 2012
the battery can't hold charge maybe? try putting it on with ac adapter plugged in and NO battery
Dell Inspiron... | Answered on Jun 15, 2012
Hook a spare monitor to the video ouput usually on the back, if picture okay! the LCD panel display from the laptop will need to be a replaced, but if both show the same symptom it is the video graphics card usually built into the motherboard.
Dell Inspiron... | Answered on Apr 26, 2012
Having stripped everything out, I found it under the motherboard at a point below the palmrest, as indicated previously.
Dell Inspiron... | Answered on Apr 09, 2012
I would guess that you have the NumLock activated.
Dell Inspiron... | Answered on Aug 16, 2011
You may need to Set the date and time in side your BIOS, you can enter inside BIOS by pressing DEL or F2 keys and set the date and time. Or you can set the time and date in windows mood also.
if still you are facing the same problem than you may need to change your CMOS battery, it can be located near RAM or may be near your H.DD inside the laptop. Replace your old CMOS battery.
Dell Inspiron... | Answered on Jul 09, 2011
It is included in the palmrest assembly. Here complete disassembly.
Dell Inspiron... | Answered on Jan 18, 2011
Hi
It sounds like an overheating problem.
The heat sinks and fans should be checked for dust, and to make sure they are working. If you do not feel comfortable opening up the computer to clean it out then I would recommend using canned air or a vacuum to carefully remove any accumulated dust from the airvents on the systems.
Make sure it is powered off and the battery and AC cords are removed before you do this.Also make sure about where the laptop is setting, dont put it on the bed, pillow, or anywhere air cannot get underneath it, raising the rear of the laptop with something[ like a deck of cards] will improve airflow, a cooling plate is even better
Dell Inspiron... | Answered on Jan 17, 2011
try 12345678... or find the cmos battery and take out (for 5 min) and reinsert back in... once you get it in go to the BIOS and change password
Dell Inspiron... | Answered on Jan 09, 2011
send me hash code .. when u turn on laptop u will see on screen hash code like this ****XXXXXXX-595B or D35b or 2A7B send me complete .ill send u password ..
Dell Inspiron... | Answered on Sep 17, 2010
There is no default password for any users for any disk.
Dell Inspiron... | Answered on Sep 15, 2010
- go to network connections
- right-click Local Area Network and select Properties
- click to highlight TCP/IPv4(vista) TCP/IP (xp)
- click properties
- change DNS servers to 8.8.8.8 and 8.8.4.4
Dell Inspiron... | Answered on Jun 03, 2010
If its yours, I believe there is a way to call Dell and after security verifications, they might be able to walk you through a back door.
The other possibility, is to remove the battery from the main board which involves taking the whole unit apart.
thanks
Dell Inspiron... | Answered on May 18, 2010
Make sure you have the drive set as "Master"
Can you tell me what error your getting?
Then I can further assist you.
Thanks
Dell Inspiron... | Answered on Apr 27, 2010
You will need to check if there's a problem with the hardware, you will have to use the built in diagnostic for your laptop or if you have the drivers disc you can run the diagnostic there. Try to go to safe mode, if you can check the recent hardware or software changes you've made,you can try to reseat the hdd, try one memory at a time, though if you have memory errors, usually you will hear a beeping sound.
Dell Inspiron... | Answered on Oct 09, 2009
Dell Inspiron 2500 Notebook Logo
35 questions posted
Ekse
Clive
Clive
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
lap top shuts off after 5 ten mins use
  • Computers & Internet
