20 Most Recent Sansui Hdlcd1955w Questions & Answers
2answers
I can't find a resolution that fits this T.V. well for my PC. And the suggested Res. (1900x1200) is not available as an option. Any help?
If the resolution is not available to your TV, there is no other way to get it. Electro help
6/8/2014 3:30:02 PM • Sansui... • Answered on Jun 08, 2014
Will not scearch for air chanels
Check and replace its tuner. It is faulty.
11/29/2013 5:56:28 AM • Sansui... • Answered on Nov 29, 2013
Black screen when windows starts to load
u should be more specific my freind but as i understand that it is a problem of resolution or refresh rate so boot the pc with another monitor & try to change the resolution & refresh rate to a desirable for ur lcd
1/18/2013 1:02:26 AM • Sansui... • Answered on Jan 18, 2013
Sansui hdlcd1955w will not power on
D/A board has some short in it. Seek tech support.
6/7/2012 9:33:19 AM • Sansui... • Answered on Jun 07, 2012
No picture or sound but menu does come up
If menu comes up power supply likely good---have you tried hooking a DVD etc to a rear input? (check all inputs if possible)
5/22/2012 4:27:13 PM • Sansui... • Answered on May 22, 2012
Can I program a Sansui television?
It depends what you want to program it into?
How Do I Program My Sansui?
Techwalla https://www.techwalla.com > Tech Support > How To Turn on the television using the "Power" button on the remote control. Press the "Menu" button on the remote to bring up the main menu for your Sansui. Use the ... ..
2/20/2024 5:45:40 PM • Sansui Televison... • Answered on Feb 20, 2024
My Sansui TV has no remote and cannot access wifi
SmartAviator, no other information is required as the question is concise as it is.
1/7/2024 11:58:49 AM • Sansui Televison... • Answered on Jan 07, 2024
Sony PlayStation PS4. How to hook to my 2009 19 inch Sansui television please?
Question edited for clarity. For a definitive answer, the television model number should have been added to check specs.
Can't get video to work on tv. Sansui HDLCD19WB and not ...
JustAnswer https://www.justanswer.com > TV Problems Sep 28, 2018 - Can't get video to work on tv. Sansui HDLCD19WB and not sure of age trying to hook up PlayStation. Menu works, no just - Answered by a ... 1 answer · Top answer: Okay, that is likely the problem here because HDMI will not convert directly to AV red, white ...
Can I connect a PS4 into any LED TV?
Quora https://www.quora.com > Can-I-connect-a-PS4-into-any-... May 3, 2018 - Usually PS4 is connected to a HD TV or 4K TV through HDMI cable which is the most obvious method. PS4 console has HDMI port just for the obvious ... 4 answers · Top answer: Hey man thanks for the request The ps4 console is connected to the tv through an HDMI cable ... Will a PS4 work with any TV? - Quora 9 answers May 26, 2018 Can a PS4 work with a 1366x768 TV (vu 32-inch ... 4 answers Nov 22, 2017 Will PS4 slim work with any TV? - Quora 6 answers Apr 5, 2017 Are Sansui 4k LED TVs any good? How do they ... 4 answers Nov 26, 2016 More results from www.quora.com
12/17/2023 11:11:14 PM • Sansui Televison... • Answered on Dec 17, 2023
2answers
Am connecting a SANSUI TV to a Dish Hopper. No problem with HDM1, but where to land the HDM2 cable at the Hopper?
I have never heard of a dish hopper before, but this tells you how to set them up. A Sansui is probably not the best choice as they are cheap and nasty televisions. https://www.google.com/search?q=Dish+Hopper+connections ..
11/4/2023 11:50:33 PM • Sansui Televison... • Answered on Nov 04, 2023
How to setup the Goldstone GS 32lcd on my Sansui TV?
You want your Sansui television to make your Goldstone television work? Or you want your Sansui television REMOTE to operate the Goldstone GS television. Neither can be done. Television makers make remotes to only work their own makes, and very often only a small series of televisions in a range that are released at the same time. Neither makes are good quality. https://universalremote.codes/goldstone-gs-32lcd-universal-remote-codes/ Get a dedicated remote for the television that is missing a remote. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
11/4/2023 3:33:27 AM • Sansui Televison... • Answered on Nov 04, 2023
How do I connect my Hisense remote control to my Sansui tv
You can't, they are two different makes and the remotes are single channel for the set that came with it. Buy a new Sansui remote. My published article explains. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
8/26/2023 12:55:41 PM • Sansui Televison... • Answered on Aug 26, 2023
2answers
Sansui led SJX32HB_2CAF service mode
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done. NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important. Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
7/2/2023 12:54:57 PM • Sansui Televison... • Answered on Jul 02, 2023
Where is the coaxial input on a Sansui television.
Sansui have specials name for it. They are always at the rear in the Connections Panel or close by. ANT 75/RF Connection Connect to the antenna/cable TV output of your device or wall plate.
Sansui - Television Model SLED3215 User Manual
Forest River https://forestriverinc.com > Component-Manuals PDF Plug earphones into jack for private listening. Overrides speakers. USB Input. This input is for service personnel only. COAXIAL Output. Connect to your SPDIF ... 39 pages
Sansui Products - Glossary ' Support
Sansui Products https://www.sansuiproducts.com > support > glossary For many Sansui televisions a coaxial connection is supported. Diagonal Size, Referred also to "Diagonal Viewing Area", the diagonal size is the size of the ...
Cable Tv Connections - Sansui HDLCD1900A Owner's ...
ManualsLib https://www.manualslib.com > ... > Owner's manual Sansui HDLCD1900A Manual Online: Cable Tv Connections. pay channels'' where the signal is ... Using another 75 ohm Coaxial box to the Antenna Jack on the TV.
qled-smart-tv.pdf
Sansui https://sansuiworld.com > assets > qled-smart-tv PDF ANT: Connect the antenna to TV via coaxial cable on ANT jack of the back panel. • AV: The output AV terminal of DVD can be connected with the AV input port ... 30 pages ..
4/28/2023 2:37:49 PM • Sansui Televison... • Answered on Apr 28, 2023
2answers
We just brought the sansui smart tv but now the picture is upside down and blurry. What can i do to fix it
1. Check if the picture settings are set properly. Make sure the aspect ratio and resolution are correct for your TV. 2. Check your TV's display menu for any "Flip" or "Mirror" options and turn them off. 3. Check the connections from your TV to your cable box or HDMI device. Try unplugging them and plugging them back in to make sure they are secure. 4. Check the TV's user manual for any specific instructions on troubleshooting picture issues. 5. If none of these steps resolve the issue, contact your TV manufacturer for more help and advice.
2/24/2023 8:37:55 PM • Sansui Televison... • Answered on Feb 24, 2023
2answers
My Sansui tv went to a black screen and has no sound
Try these steps to fix the issue with your Sansui TV:
  • Check connections and source
  • Ensure TV is on and power cord plugged in
  • Reset the TV by unplugging it and plugging it back in
  • Verify audio settings and that speakers are on
  • Contact manufacturer for further assistance if needed.
1/31/2023 1:11:32 AM • Sansui Televison... • Answered on Jan 31, 2023
How do I hook up a VCRDVD player to my sansui flat screen TV and what do I need to do in terms of channels or inputs or setup to get this accomplished
To connect a VCR/DVD player to a Sansui flat screen TV, you will need to use the appropriate cables and connections. Here are the general steps you can follow:
  1. Check your TV and VCR/DVD player for the available ports. The TV should have RCA composite video and audio inputs, and the VCR/DVD player should have RCA composite video and audio outputs, or HDMI port.
  2. Using the appropriate cables, connect the RCA composite video and audio outputs from the VCR/DVD player to the corresponding RCA composite video and audio inputs on the TV. If your VCR/DVD player has HDMI port, use HDMI cable to connect the TV and the VCR/DVD player.
  3. Turn on your TV and VCR/DVD player.
  4. On your TV, press the "Input" or "Source" button to switch to the input where the RCA composite video and audio cables are connected or HDMI.
  5. Using the remote of your TV, go to the menu and select the input where the VCR/DVD is connected.
  6. If you don't see any picture, try adjusting the settings on your TV and VCR/DVD player.
  7. Once you are able to see the picture on your TV, you should be able to use your VCR/DVD player as you normally would.
1/13/2023 5:52:30 AM • Sansui Televison... • Answered on Jan 13, 2023
Sansui model hdl19wb series a how do I hook up a VCR DVD player to the TV and what inputs and how do I do the setup
Is the DVD/VCR a single unit? What is the TV you are going into and what are you inputs and outputs? Are they HDMI, VGA, Component?
1/12/2023 9:24:02 PM • Sansui Televison... • Answered on Jan 12, 2023
Sansui Hdlcd1955w Logo
6 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
black screen when windows starts load
  • Televison & Video
