FixYa.com
Epson Expression 1640XL Pro Flatbed Scanner
All Products > Epson > Scanners
Problems with Epson Expression 1640XL Pro Flatbed Scanner?
Search inside Epson Expression 1640XL Pro Flatbed... Knowledgebase
Troubleshooting and Support
Solved Problems for Epson Expression 1640XL Pro Flatbed Scanner RSS Feed Post a New Problem
error message on Epson 1640 XL scanner
I get an error message that says"unspecified message" on my scanner and can not scan...Help please
1 Solution
Memory Allocation problem with Epson...
I contacted Epson about my problem but they said to contact Adobe, so I'm trying the message board here. I'm trying...
8 Solutions
How to test a scanner for color...
How to test a scanner for color registration?
1 Solution
Which file format is proper to save the...
Which file format is proper to save the scanned image?
1 Solution
How to Connect a Parallel Scanner to a...
How to Connect a Parallel Scanner to a Computer?
1 Solution
My CanoScan D1230U has stopped working
Resentley fter years of use my CanoScan D1230U has stopped working. Everyting was connected properley but it still...
1 Solution
scanner instruction
I would like the instruction for lexmark x 4.270
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Epson Expression 1640XL Pro Flatbed Scanner RSS Feed Post a New Problem
Epson 1640SU scanner, red line in all...
Whenever I do a scan both the preview and the actual scan have a red line running the full length of the scan. I goes...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformMac, PC
TypeFlatbed Scanner
InterfaceUSB · SCSI
Optical Resolution1600 dpi
Max. Resolution (Hardware)1600 x 3200 dpi
Max. Gray Depth14-Bit Gray
Technical Features
Form FactorDesktop
Input TypeColor
Media
Supported Media TypeTransparencies · Plain Paper
Media Loading MethodManual Load
System Requirements
Operating SystemApple MacOS 8 · Microsoft Windows 95
Dimensions
Depth18.05 in.
Height6.93 in.
Width25.85 in.
Weight46.31 lb.
Warranty
Warranty1 Year
Epson Contact Information
Main support number1-800-922-8911
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
