FixYa.com
Epson Expression 1680 Flatbed Scanner
All Products > Epson > Scanners
Problems with Epson Expression 1680 Flatbed Scanner?
Search inside Epson Expression 1680 Flatbed Scanner Knowledgebase
Troubleshooting and Support
Solved Problems for Epson Expression 1680 Flatbed Scanner RSS Feed Post a New Problem
Flatbed scanner for MF
I'm considering buying a flatbed scanner for negatives up to 6x9. I caertainly can't afford a real MF filmscanner. ...
23 Solutions
The file size of my saved image is too...
The file size of my saved image is too big, i cant work with it, is there anything i can do?
1 Solution
How to test a scanner for color...
How to test a scanner for color registration?
1 Solution
How can i Use a Scanner to Capture Text?
2 Solutions
Which file format is proper to save the...
Which file format is proper to save the scanned image?
1 Solution
How to Connect a Parallel Scanner to a...
How to Connect a Parallel Scanner to a Computer?
1 Solution
My CanoScan D1230U has stopped working
Resentley fter years of use my CanoScan D1230U has stopped working. Everyting was connected properley but it still...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Epson Expression 1680 Flatbed Scanner RSS Feed Post a New Problem
scanner 1680
lid won,t close completely
Post a Solution
Scanning stops
I haven't used my scanner for a month. It worked well then. I tried to scan 8 color slides. It got through the first...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformMac, PC
TypeFlatbed Scanner
InterfaceUSB · SCSI-2 Fast (8-bit)
Optical Resolution1600 dpi
Max. Resolution (Hardware)1600 x 3200 dpi
Max. Gray Depth16-Bit (64K Gray Levels)
Technical Features
Form FactorDesktop
Input TypeColor
Media
Supported Media TypePlain Paper · Bulk Objects (Books, etc.)
Media Loading MethodManual Load
Max. Supported Media Size216 x 297 mm
System Requirements
Operating SystemApple MacOS 8 · Microsoft Windows 95 · Microsoft Windows 2000 · Microsoft Windows ME
Dimensions
Depth22.14 in.
Height5.24 in.
Width13.08 in.
Weight18.74 lb.
Warranty
Warranty1 Year
Epson Contact Information
Main support number1-800-922-8911
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
