20 Most Recent Mitsubishi LT55164 Unisen Medallion 55 1080p 120Hz LED HDTV Questions & Answers
I need to be able to connect DVD player to output 3 on Mitsubishi Medallion hdtv 1080 we can't seem to get it to work
It needs to be input if you want to display some on the TV from the DVD player. HDMI is the easiest as it's both audio and video.
6/3/2015 1:36:58 AM • Mitsubishi... • Answered on Jun 03, 2015
Hdtv flashing green light for timer tv wont turn on
If the TV is a few years old the flashing green light means the bulb need to be replaced. That's why the TV will not show a picture. Check your owners manual on how to replace.
3/4/2015 1:19:45 AM • Mitsubishi... • Answered on Mar 04, 2015
I have a Mitsubishi Medallion HDTV 1080 and we had a power outage and now the green timer light is blinking rapidly. Hitting the reset button does not work nor unplugging the system for a long period
either go get it fixed or trash it , some of them have a fuse on them just for that purpose but I never seen one blow even with a outage
2/3/2015 4:12:11 PM • Mitsubishi... • Answered on Feb 03, 2015
Timer/power light is flashing. hit reset still nothing. what can I do
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
11/1/2014 1:33:17 AM • Mitsubishi... • Answered on Nov 01, 2014
How to change inputs
Just press input button on the remote or the TV. Sometime they label input as Source. www.aaatvservice.com
8/16/2014 12:43:52 AM • Mitsubishi... • Answered on Aug 16, 2014
Tv turns on and then off after 4 secs
You may have it on power saving. Go to your menu and check to see what the time is set for to turn off if it is on power saving mode.
1/8/2014 7:42:14 PM • Mitsubishi... • Answered on Jan 08, 2014
Our TV blinks back and forth between the picture and a black screen while the audio remains the same.
Check and replace its backlight CCFL lamps.
6/22/2013 8:58:22 AM • Mitsubishi... • Answered on Jun 22, 2013
Mitsubishi DLP 73 inch TV WD-73738 is blinking 6 red and 1 yellow, replaced the color wheel, and still having the same problem?
The lamp is not enabled possibly due to the colour wheel motor not turning. Any broken glass jamming it? Or the lamp ballast has failed due to an old/worn lamp.
4/10/2024 7:05:08 AM • Mitsubishi... • Answered on Apr 10, 2024
2answers
I have a mitsubishi dlp tv model wd 60738 and when i turn it on the power button blinks for a second and then it stops but no picture and after while turns off
Most likely you need to replace the projection bulb. You can find them online. DLP sets are famous - or infamous - for burning out the bulbs/lamps.
3/11/2024 7:56:47 PM • Mitsubishi... • Answered on Mar 11, 2024
Mitsubishi VCR HS-U580 guide rollers not moving forward all the way. Cassette would not load. Also noticed drum not spinning when powered on
Your Mitsubishi VCR HS-U580 looks to have a problem with the information rollers and drum. Here are some things to check: Look for something blocking the VCR or cassette compartment that would possibly be stopping the guide rollers. Check the belt that drives the VCR mechanism. If it is loose or broken, you may also need to substitute it. Clean the video heads using a head-cleaning cassette to make certain they're not dirty. See if the drum motor is working. If it is not spinning, there may be an issue with the motor. If the trouble persists, it's an exact idea to get assistance from a professional technician or contact Mitsubishi's purchaser support for advice. Be cautious when dealing with electronic devices, and if you are not certain what to do, it's great to get assistance from an expert.
2/20/2024 5:32:32 PM • Mitsubishi... • Answered on Feb 20, 2024
Where could I download a copy of a service manual for mitsubishi hs-u580 vcr?
i think finding a downloadable service manual for your Mitsubishi HS-U580 VCR might take some searching, but here are a few options: Check the official Mitsubishi website's support section. They might offer downloadable manuals for older models.Many online appliance parts stores like RepairClinic or AppliancePartsPros stock service manuals for various brands and models. Search for your specific VCR model to see if they have it available.Websites like ManualsLib or iFixit sometimes host user-uploaded service manuals. While the availability and quality can vary, it's worth checking. If online options fail, consider purchasing a physical copy of the service manual from online marketplaces like eBay or Amazon. Remember, some websites might charge a fee for downloading manuals. Always be cautious of suspicious websites and download from reputable sources.
2/12/2024 8:58:07 PM • Mitsubishi... • Answered on Feb 12, 2024
Looking for power cord replacement for Mitsubishi model #LT-55164
You can purchase a replacement power cord for your Mitsubishi model #LT-55164 from TVserviceParts.com. The part number for the power cord is 246C638010 and it costs $18.40.
12/30/2023 8:16:17 PM • Mitsubishi... • Answered on Dec 30, 2023
I own a Mitsubishi 1080 1EEE 1394 television. Yesterday, we had a planned power outage in our area. When the power was restored, the only picture I can get is flipping horizontal lines?
Hoping you did not have electric overload that damaged the power supply, try unplugging the set and push the button On until no lights indicate anything. Then wait about an hour so the capacitors would empty themselves further. Next plug it back in and see if this worked. It is never wrong to push the edges a little in finding if the cables that go around the screen have a problem at that point. When one opens the TV (off power and unplugged) these flat cables should be checked for corrosion and right position in connectors. Corrosion is caused by little moist only, combined with the electricity. Then see if capacitors from the power supply, or any at all, have expanded tops. Those are the larger and smaller towers with metal on top that is divided in three parts. New ones alike can then be ordered but replacing requires basic skills. Further examples can be found on YouTube. Capacitors are common to fail early. Those larger ones have dangerous high voltage and can hold their charge for long span of time. it is not uncommon for devices like this to fail after being off.
10/16/2023 2:11:33 AM • Mitsubishi... • Answered on Oct 16, 2023
Mitsubishi WS-65511 Projection Television won't turn on.
Question edited for clarity. 'make model (what it is)'. Question moved from Cell Phones category. 12 ----------- indicates no error 21 ------------- X-Ray Protect circuit 22 ------------ Short Protect circuit 23 ------------- Horizontal Deflection failure 24 ------------- Vertical Deflection failure https://www.google.com/search?q=Mitsubishi+WS-65511+code+22 Antique technology ..
9/16/2023 5:38:18 PM • Mitsubishi... • Answered on Sep 16, 2023
I have a Mitsubishi TV LT-55154 with no picture it has sound but no picture. The green light is solid.
If your Mitsubishi TV LT-55154 has no picture but has sound and the green light is solid, there are a few potential causes for this issue:
  1. Faulty backlight: The backlight in your TV is responsible for illuminating the screen. If the backlight is not functioning properly, it can result in a black screen while still producing sound. You can try shining a flashlight on the screen at different angles to check if you can see any faint images. If you can, it indicates a backlight issue. In such cases, the backlight unit may need to be replaced. Contact a professional technician or the manufacturer's support for further assistance.
  2. Loose or damaged cables: Check that all the cables connecting your TV to external devices (such as cable/satellite boxes, DVD players, or gaming consoles) are securely plugged in. Ensure that there are no loose connections or damaged cables, as this can lead to a loss of video signal.
  3. Incorrect input/source selection: Make sure that the TV is set to the correct input or source that corresponds to the device you want to watch. Use the TV remote to cycle through the available input options and see if the picture appears on any of them.
  4. Display settings: It's possible that the display settings on your TV have been inadvertently adjusted or misconfigured. Check the TV's menu options for any settings related to picture or display, such as brightness, contrast, or picture mode. Resetting these settings to their default values might help resolve the issue.
  5. Hardware malfunction: In some cases, a hardware malfunction within the TV, such as a faulty video processing unit or mainboard, can cause a loss of picture. In such situations, it's recommended to contact a professional technician or the manufacturer's support for further troubleshooting and potential repairs.
Remember to exercise caution when working with electronics, and if you are unsure about any steps or lack the technical expertise, it's best to seek professional assistance to avoid causing further damage to your TV.
6/18/2023 9:06:57 PM • Mitsubishi... • Answered on Jun 18, 2023
Mitsubishi LT55164 Unisen Medallion 55 1080p 120Hz LED HDTV Logo
9 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
need able connect dvd player output 3
  • Televison & Video
