20 Most Recent Fujitsu LIFEBOOK B2610 PC Notebook Questions & Answers
get a 98 or a xp disk
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Fujitsu LIFEBOOK... | Answered on Feb 20, 2008
your problem could be that the hard drive is broken, perhaps with some tool to repair hard disks the problem. test starting for example hiren boot from a memory or cd and see if it recognizes the hdd, if so you can pass some repair tool
Fujitsu LifeBook... | Answered on Nov 21, 2017
remove the bios password by removing the cmos battery, removing the jumper from the pins right next to the battery, marked something like pswd, plugging it in and hitting the start button.Before you open the case, unplug, remove the bettery, then hold the start button to get rid of any energy.
Fujitsu LifeBook... | Answered on May 14, 2016
please mention the laptop model
Fujitsu LifeBook... | Answered on Apr 29, 2016
Sounds like liquid may have been spilled on the keyboard.
Plug in an external usb keyboard and check if it works.
If so, you will need to buy a replacement keyboard and swap it out, best cheap from Ebay.
Fujitsu LifeBook... | Answered on Dec 06, 2015
1) Try plugging in an external usb mouse incase you have disabled the mouse pad by mistake
2) Force a reboot and press F8 just past the BIOS screen
Choose Last known good configuration from the list
Google search your manufacturer make and model and the word manual. If one is available, you can find it in the search results.
Fujitsu LifeBook... | Answered on Apr 01, 2015
Google search your manufacturer make and model and the words reset button location. You can find it in the image search results. You could also try the manual, which should show the location.
Normally there is a hardware switch on the side of the laptop
Sometimes you can press on the keyboard some buttons like this -
Activate by pressing FN (on same line as spacebar in blue) and then a button that looks similar to this one.
Fujitsu LifeBook... | Answered on Mar 30, 2015
Ctrl and PrntScrn together will copy your desktop to the notepad. Print Screen was outdated with the onset of Windows. It is a DOS command.
Fujitsu LifeBook... | Answered on Mar 02, 2015
The Numlock key should toggle, on/off.
Fujitsu LifeBook... | Answered on Feb 16, 2015
Purchase a copy from Microsoft.
Fujitsu LifeBook... | Answered on Feb 12, 2015
It depends upon the type of usage. In a technical review, a battery test was performed where they disable power management, maximized the screen brightness and enabled the wireless radio while looping video files, it lasted 1hr 33min. This is an extreme, and using power management and turning down or off items not needed, the battery life will be longer. Mileage varies by user.
Fujitsu LifeBook... | Answered on Feb 05, 2015
You have two options. First check the ribbon cable that is is attached to the motherboard and the screen. If the cable is firmly attached, it could be one of two things. A bad ribbon cable, or a bad screen. Then only option would be to replace one or another, or both if you prefer.
Fujitsu LifeBook... | Answered on Jan 13, 2015
Fujitsu LIFEBOOK B2610 PC Notebook Logo
Popular Tags
2 questions posted
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
LifeBook Fujitsu
  • LifeBook Fujitsu
Most Popular Question
drivers
  • Computers & Internet
