20 Most Recent
Samsung UN32EH5300FXZA 32 in. HDTV Questions & Answers
Power board and back lights led tv
BL Inverter board fault. It's not working [oscillating]. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
6/28/2016 5:07:32 AM •
Samsung...
Answered
on Jun 28, 2016
No pic only sound
Hi Alee,
Do you get menu? If no, it is the back lights problem. Otherwise the main board seems to be causing this problem. In either case you will have to consult the TV tech.
Good luck.
4/15/2015 7:29:32 PM •
Samsung...
Answered
on Apr 15, 2015
Samsung le26a6 will not switch on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
