20 Most Recent
Fujitsu Siemens SCENIC D PC Desktop Questions & Answers
Find the harddisk
The hard drive may be failing, or just the OS or hard drive corrupted. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive.
Then, you could try to do a Factory Restore on the computer, and if that works, copy your personal files back to your newly restored computer.
Good luck
Can not find bios image
Hi, The, motherboard needs to be replaced for the same. The BIOS controls how the motherboard interacts with all the hardware attached to your computer in the inside and outside of the PC. The BIOS chip can be replaced or re-programmed on the faulty motherboard, but getting a new motherboard is a better alternative to the same.RegardsProton
Sound recorder
We cannot answer because. Big size memory get much more then small memory also you can set up the quality for the voice. The quality one and low quality has much different.. That up to you.
Realtek ac97 line in recording problems
you must configure the record system. Be shure if you virus, malware, had been penetrated in your sistem. if the machine was working before recording, restore the system.God bless you
HOW TO RESET THE BIOS PASSWOrD FOR FUJITSU LH532
THERE ARE 3 LEVELS STATED IN THIS 2012 MANUAL BIOS.
SUPERVISOR (ADMIN)
USER
AND BOOT PW.
1,2,3 Three kinds/
and 2012 PC is w8 ready meaning the old COIN pulled way is now useless, as the manual told you, page 10
if ADMIN is set , bios screens are locked out. on purpose
boot pass word blocks windows from booting. not entered correctly.
if TPM was set the PC is locked out, hard. by design.
TPM set and then cleared using ADMIN login, all data is lost. gone
by DESIGN TPM rules and laws there of.
we can;'t see what is set in your bios. so....
now level 4, HDD security page12 if set that too is locked out.
we can't see any of this in a text box.
if you bought it locked out send it back
if from a friend as a handme down, ask them for the PW.
or guess.
or google backdoor passwords
FUJITSU LH532
page 10 says (see photo and learn this)
https://www.manualslib.com/manual/829337/Fujitsu-Lifebook-Ah532.html?page=10&term=reset&selected=2#manual
see the will not word,
that means ONLY HACKING works and we are not hackya dot com.
google for hacks if you want.
all PC laptops 2012 and newer the rules are strict.
next time don't set this junk. or write it down next time.
6/18/2022 3:13:13 PM •
Fujitsu...
Answered
on Jun 18, 2022
