20 Most Recent Emerson 32-inch 720p LED TV Refurbished Questions & Answers
Does it work ok with cable or antenna hooked up to it?
Emerson 32-inch... | Answered on Nov 29, 2017
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Emerson 32-inch... | Answered on Oct 01, 2016
Lots of variables, here. What is your source - off-air broadcast? cable? DVD or Blu-ray player? Other? Are you going through an AV receiver? What loudspeaker system are you using? What's the model # of your TV?
Emerson 32-inch... | Answered on Oct 16, 2014
What is the problem you faces with this TV? Provide more details, please. google.com/+GopakumarGopalan
Emerson 32-inch... | Answered on Nov 26, 2013
does anyone have the part # for the power inverter transformer for the LC320EM2 A the board #BA1AFGF0102 2. The transformer I am looking for is the largest yellow transformer, thnks.
Emerson 32-inch... | Answered on Nov 09, 2012
There are replacement remotes and universal remotes that may work. This one is an exact replacement without the Emerson branding: https://www.remotes.com/emerson-p/emerson-rtnb118ud-insert.htm .
I hope this helps.
Emerson... | Answered 13 hours ago
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Emerson... | Answered on Mar 13, 2019
repair shops give free estimates usually
Emerson... | Answered on Mar 12, 2019
If I am not mistaken.... judging only from experience and not researching your products, that giant remote is ir (infrared) and if I'm not mistake the roku is bluetooth remote. The giant remote is not bluetooth capable or RF to my knowledge, the roku is not ir compatible as far as i know even if its not bluetooth it would be some variation of it i.e RF. Good luck
Emerson... | Answered on Mar 02, 2019
Change your video source - input. If you don't see anything, there maybe a problem with TV. You can do a hard reset by unplugging TV from outlet for 15 minutes. If you are still unable to view anything, like video input message from TV, you have a more serious problem. Is your TV a CRT or LED/LCD? If your emmerson is a CRT, it's most likely the TV lamp. You can look on Amazon or ebay and pic one up for under $100. If it's a LED or LCD, it can be the motherboard. Which you can also find for under $100.
Emerson... | Answered on Feb 25, 2019
SADLY WHISKEY IF WE ONLY HAD ALL THE ANSWERS THERE WOLD BE NOTHING ELSE TO DO WOULD THERE.
Emerson... | Answered on Feb 24, 2019
Emerson 32-inch 720p LED TV Refurbished Logo
7 questions posted
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Televison & Video
Most Popular Question
emerson 32 inch led tv having some
  • Televison & Video
