Gateway Motherboard
Problems with Gateway Motherboard?
Troubleshooting and Support
Solved Problems for Gateway Motherboard RSS Feed Post a New Problem
Processor upgrade for Tabor 2 Gateway part...
After doing some research and upgradeing to a P3 450 I found an interesting issue about the motherboard. A 450...
4 Solutions
date being set to 2099 - Bios problem?
I have a PII 266 that  often sets the year to 2099. the rest of the dat is correct. This happens on boot before...
13 Solutions
usb driver motherboard transcend win 98
ts-avd3 i need to download driver for usb driver motherboard transcend win 98
1 Solution
Motherboard Jumper spots
I installed a working motherboard. Now I can not find the correct jumpers to put these pins on it like Power Switch, HDD...
1 Solution
regarding compatible memory
i have a board ecs k7ama i wanna know its specification and the compatibility of memory aside from 266 thanks
1 Solution
Packard Bell Imedia 1402 wont boot up
Hi When I try and boot up my PB Imedia 1402, the power LED flashes and the power button flashes yellow. Also, when I...
1 Solution
Mainboard OC Failure
Hello. I have a problem with overclocking. My mainboard is MSI 945P Platinum. When I try to overclock it to more than...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
CompatibilityPC
ChipsetIntel 440BX
Compatible ProcessorsIntel Pentium II
Technical Features
Expansion SlotsPCI x 4 · ISA x 2 · AGP x2 x 1
Integrated Input/Output PortsSerial Port x 2 · USB 1.1 x 2 · PS/2 Mouse x 1 · PS/2 Keyboard x 1 · Parallel Port (ECP/EPP/SPP) x 1 · Game/MIDI Connector x 1 · Floppy Port x 1
Storage Controller Type(s)DMA/ATA-33 (Ultra) x 2
Processor
Max supported CPUs qty1
Socket TypeSlot 1
Memory
Max Supported RAM384 MB
Memory TypeSDRAM
Supported RAM Speeds100 MHz · 66 MHz
Number of Memory Slots3 x 168 Pin SDRAM DIMMs
Audio / Video
Audio OutputLine Out
Video InterfaceAGP
Audio InputMicrophone Jack · 2 x Line In
Integrated AudioAC'97 Audio Codec
Other Features
Package Qty1
Fans3 x 3-pin fan headers
Gateway Contact Information
Main support number800-369-1409
Sponsored Links
Loading problems.
Top Experts
Ask Me
map9966 Guru
58 solutions
Ask Me
yoboyace Master
1 solutions
Ask Me
JoAT Wiz
1 solutions
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
