Gateway Motherboard
Problems with Gateway Motherboard?
Keep your PC up-to-date. Get a Free Scan for Gateway's latest driver updates.
Troubleshooting and Support
Solved Problems for Gateway Motherboard RSS Feed Post a New Problem
On the MSI 7145 v2 motherboard, some...
ON jA1 I was able to get the hdd yellow led and the blue power led operational, but I can't seem to get the power...
1 Solution
sobre micro y placa madre
deseo saber ademas de el soket 7 si le sirvbe a la aptiba de ibam potro tipo de micro conotro soket o se le puede adptar...
1 Solution
connecting the motherboard, system panel...
Hello, Can help me by illustrating the correct way to connect the System panel header on the P4i65G?My problem is that...
1 Solution
Re boot
Hi Shayna!I have Acer Extansa2000.I want to reboot my windows,but i have no any mother board install cd,becose i buy...
1 Solution
case wire two mother board
need help with puting them back in right place
1 Solution
Acer Aspire 1360 d/c input port
Acer Aspire 1360 Lapop I have had problems with charging the battery staying charged for more than 20 minutes and or...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Form FactorATX
Compatible ProcessorsIntel Pentium II
Front Side Bus Speed100 MHz
Technical Features
Expansion SlotsAGP x4 x 1 · PCI x 4
Integrated Input/Output PortsSerial Port x 2 · USB 1.1 x 2 · PS/2 Mouse x 1 · PS/2 Keyboard x 1 · Parallel Port (ECP/EPP/SPP) x 1 · Floppy Port x 1
Storage Controller Type(s)DMA/ATA-33 (Ultra) x 2
Processor
Max supported CPUs qty2
Socket TypeSlot 1
Memory
Max Supported RAM1 GB
Memory TypeSDRAM
Supported RAM Speeds100 MHz · 66 MHz
Number of Memory Slots4 x 168 Pin SDRAM DIMMs
Other Features
Package Qty1
Chassis TypeDesktop
Gateway Contact Information
Main support number800-369-1409
Sponsored Links
Loading problems.
Top Experts
Ask Me
map9966 Guru
58 solutions
Ask Me
yoboyace Master
1 solutions
Ask Me
JoAT Wiz
1 solutions
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
