20 Most Recent Epson WorkForce WF-7520 Wide Format All-in-One Printer Questions & Answers
i have the same printer,i had to clean the heads 14 times to get yellow to finally work
Epson WorkForce... | Answered on Jun 22, 2015
Well, it would be good to know why the photos are not good quality... like blurry or bad color or? Are you using a good paper? I have great luck with Canon glossy, and love the matte paper from Staples. Matte is actually easier and all around better color saturation, I find. I guess that you are using too much saturation of ink... see if your dialog box for printer options has a way to make saturation less intense. Also, I assume you are using the same dialog box to choose the type of paper. That is important, since different papers absorb ink at different speeds and amounts. I hope that helps... keep trying!
Epson WorkForce... | Answered on Nov 07, 2014
You need to start with photo glossy paper that's designed for an Epson printer. HP paper may not work well, and some other papers don't work either. Try some Epson paper, and that should work fine.
You can also try other paper settings, such as "transparency" or "matte paper", as the paper setting governs how much ink is laid down. I think getting the right paper is really what you need, though. Ink "puddling" is a common Epson complaint, and it's almost always the paper.
Epson WorkForce... | Answered on Nov 03, 2014
Check you printer settings on the printer. Also, check where the paper is supposed to be dispenced.
you can put the number of page you need to print
Epson WorkForce... | Answered on May 30, 2014
As far as the wifi is concerned, try getting it connected to your home network. Once it gets connected, go into your network settings and try to get the IP address. If you can obtain that, you should be able to add a network printer using TCP/IP port. Also, see if you can factory reset the printer, and start the setup all over.
Epson WorkForce... | Answered on Feb 17, 2014
Have you tried setting the paper size for each cassette, then setting the printer to Auto instead of selecting the cassette?
Epson WorkForce... | Answered on Nov 18, 2013
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
There maybe bits of paper still stuck, carefully remove
Epson WorkForce... | Answered on Oct 20, 2013
go to properties in the printer and adjust for paper size and orientation or print fit to paper. Apply settings before closing out.
Epson WorkForce... | Answered on Aug 04, 2013
it sound as though you have a bad cartridge. Take it out and shake it, if it is a tonercart. or blot it against a damp cloth if it is an injet.
Epson WorkForce... | Answered on Sep 07, 2012
Locate the control panel of your Epson printer. It is usually on the top right-hand side of your printer, near any digital display screen that the printer may have, and where the button used to turn the computer on and off is also located. Find the button marked Pause/Reset on the row of buttons on the control panel.
Epson Office... | Answered 17 hours ago
Epson WorkForce WF-7520 Wide Format All-in-One Printer Logo
27 questions posted
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Epson Office Equipment & Supplies
Most Popular Question
correct settings printing semi gloss
  • Office Equipment & Supplies
