20 Most Recent Savin C2525 Yellow Developer Genuine Questions & Answers
What is the expected image count on a Savin C2525 Color Drum?
80,000 pages
10/26/2014 1:59:18 PM • Savin C2525... • Answered on Oct 26, 2014
Error on savin clp 340d sc548 error fuser but the fuser is working what else can be the problem
The contacts on the fuser may need polishing, or control boards that operate the fuser are faulty. Call for service.
10/28/2022 4:25:10 PM • Savin Office... • Answered on Oct 28, 2022
2answers
Where is located the sensor for fuser savin clp 340d printer
Hi, please check for the fuser behind or around the drum units of your Savin printer. This is a common location for this item in printers in general. Thank you.
10/28/2022 2:32:44 AM • Savin Office... • Answered on Oct 28, 2022
Savin 917 Copies are faded on the Left side of page.
Kenneth: I would remove and cover the drum carriage (to protect the drum from damage by exposure to light), and check and clean the corona wires. There is a charge corona and a transfer corona, so that's two coronas that you'll have to clean. If you can remove the coronas from the machine, you can do a better job of cleaning the coronas. A faded line down the page like you're getting could be a paper shard stuck to one of the coronas... it's been known to happen.
9/16/2019 8:59:29 PM • Savin Office... • Answered on Sep 16, 2019
What is an error code SC364 on a Savin C3333?
This indicates that the harness and/or the td sensor on the black pcu has gone bad. It is recommended to replace the black pcu to resolve the problem.
5/17/2019 1:01:10 PM • Savin Office... • Answered on May 17, 2019
What means Service call code SC565 on a savin C3030 printer?
That code is most likly fuser code, could be blown fuse, or fuser may have to be reset by getting into service mode, Yellow key 107 red key, now in svc mode. look for tab that says mode. depress and look for code to reset fuse coul be 5810 and depress excute. turn on off that should reset fuser if code comes back you have bad fuser, fuser, lamp etc.
5/7/2019 6:54:25 PM • Savin Office... • Answered on May 07, 2019
Savin c9020 with sc400
3/20/2019 6:31:27 AM • Savin Office... • Answered on Mar 20, 2019
2answers
SC 590 on a Savin 917. Looks like I need to replace the drum. Bad Copy Qual.
sc 590 is an exhaust fan motor error the fan could be failing as for the copy quality the pcu will probably solve that problem
1/29/2019 4:25:59 AM • Savin Office... • Answered on Jan 29, 2019
Savin c9125 toner is coming off of paper what is the problem
first try hitting the # key , then select thick paper 2, ok, then try to copy again..
this changes heat and speed settings.
1/29/2019 4:01:46 AM • Savin Office... • Answered on Jan 29, 2019
2answers
I replaced the black cartridge and I keep getting an error message to replace the toner on the Savin c3030
that would be a machine malfunction already try to see the entrance of the printer near the ribbon if attached correctly maybe some small parts have been malfunction near the cartridge slot
1/28/2019 8:44:18 PM • Savin Office... • Answered on Jan 28, 2019
Savin CLP131DN the Paper Tray will not open. It appears to be jammed or stuck on something. It is empty and I am having to manually feed paper until I can get the tray opened.
Try taking off the back covers of the machine, especially the bottom back cover. It may allow you to look into the tray from the back of the machine and allow you to see what is obstructing the tray from being pulled out. Good luck.
1/16/2019 12:02:57 AM • Savin Office... • Answered on Jan 16, 2019
2answers
How do I fix a used toner bottle is full message on a Savin 4035Esp copier?
remove the used bottle. Turn off the machine. Turn on the copier and follow the directions. If it does not work, turn it off again, put in a new bottle then turn on. If that doesn't work, turn it off and try to get a refund on your new bottle of toner.
11/8/2018 6:51:02 AM • Savin Office... • Answered on Nov 08, 2018
Savin C2525 Yellow Developer Genuine Logo
1 questions posted
Top Savin Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Ngoro
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Savin Office Equipment & Supplies
Most Popular Question
expected image count savin c2525 color
  • Office Equipment & Supplies
