FixYa.com
IBM ThinkPad X40 PC Notebook
All Products > IBM > PC Laptops
Problems with IBM ThinkPad X40 PC Notebook?
Search inside IBM ThinkPad X40 PC Notebook Knowledgebase
Troubleshooting and Support
Solved Problems for IBM ThinkPad X40 PC Notebook RSS Feed Post a New Problem
Keyboard problem with IBM R52
Keyboard problem with IBM R52 I got IBM Thinkpad R52 but having one problem. when i type letters on the keyboard numbers...
1 Solution
ibm thinkpad x40 keyboard problem numbers...
okay i changed the keyboard the manual was great i can't get the keyboard unlocked from the numbers showing up its the...
1 Solution
LAPTOP KEYBOARD FOR IBM THINKPAD X40 X41...
how do i get the old keyboard off and reinstall new one thanks matty
1 Solution
thinkpad x40 cannot see the wireless...
My wireless wasn't connecting. I decided to remove the connection. When I went to add it back to the machine - aka add...
1 Solution
IBM X40 hangs on startup - intermittently
This happens after the Win default screen background appears ... the startup process stops. It does not happen on each...
1 Solution
Should I buy an extended warranty?
1 Solution
Can I disable deffective Keys?
I spilled a smoothie on my keyboard and the two top right keys are repeating I think they are the Control Key and the...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Operating SystemMicrosoft Windows XP Professional · Microsoft DOS
ProcessorIntel Pentium M 1.5 GHz · Intel Pentium M 1 GHz · Intel Pentium M 1.4 GHz · Intel Pentium M 1.3 GHz · Intel Pentium M 1.1 GHz · Intel Pentium M 1.2 GHz
Installed Memory1 GB (DDR SDRAM) · 256 MB (DDR SDRAM) · 512 MB (DDR SDRAM)
Recommended UseCorporate Business, Small Business · Corporate Business, Small Business, Home Use · Corporate Business
DisplayXGA TFT LCD · 12.1 in. XGA TFT LCD · 12.1 in. TFT Active Matrix LCD · 12.10 in. TFT Active Matrix · 12.10 in. XGA TFT LCD
Mobile TechnologyIntel Centrino Mobile Technology · Wi-Fi Certified
Hard Drive40 GB, 4200 RPM
Processor
Processor TypePentium M
Processor Speed1 GHz · 1.2 GHz · 1.3 GHz · 1.4 GHz · 1.5 GHz · 1.1 GHz
Processor ManufacturerIntel
Processor Number758 · 738 · 733
Motherboard
Bus Speed400 MHz
ChipsetIntel 855GME · Intel 855PM
Display
Display Size12.1 in. · 12.10 in.
Display TechTFT Active Matrix · XGA TFT LCD · TFT Active Matrix LCD
Display Max. Resolution1280 x 1024 · 1024 x 768
Display Color Support24-bit (16.7 million colors)
Technical Features
Expandability1 x Type I/II PC Card Slot, 1 x SD Card Slot · 1 x Type I/II PC Card Slot · 1 x Type I/II PC Card Slot, Docking Station/Port Replicator · 1 x Type I/II PC Card Slot, 1 x SD Card Slot, Docking Station/Port Replicator · Docking Station/Port Replicator, 1 x Type III PC Card Slot · 1 x SD Card Slot, Docking Station/Port Replicator, 1 x Type III PC Card Slot
Security FeaturesHDD Password, Power-On Password, IBM Embedded Security Subsystem 2.0, Administrator Password, IBM Security Slot, Security Chip (TCPA/Crypto 3) · HDD Password, Power-On Password, IBM Embedded Security Subsystem 2.0, Administrator Password, IBM Security Slot · HDD Password, Power-On Password, Administrator Password, IBM Security Slot · HDD Password, Slot For Cable Lock, Power-On Password, IBM Embedded Security Subsystem 2.0, IBM Security Slot · HDD Password, Power-On Password, Administrator Password, IBM Security Slot, Security Chip (TCPA/Crypto 3) · HDD Password, Setup Password, Power-On Password, IBM Embedded Security Subsystem 2.0, IBM Security Slot · IBM Embedded Security Subsystem 2.0
Expansion Ports2 x USB 2.0 · 2 x USB 2.0, VGA out, RJ-11 (modem), RJ-45 (NIC), S-Video out · 2 x USB 2.0, VGA out · 2 x USB 2.0, VGA out, RJ-11 (modem), RJ-45 (NIC) · 1 x USB 2.0, 2 x USB 1.1, VGA out, RJ-11 (modem), RJ-45 (NIC) · 4 x USB 2.0, VGA out, RJ-11 (modem), RJ-45 (NIC) · 1 x USB 2.0, VGA out, RJ-11 (modem), RJ-45 (NIC)
Hard Drive
Hard Drive Capacity20 GB · 30 GB · 40 GB
Storage Controller TypeEIDE · IDE · Ultra ATA · Ultra ATA 100
Hard Drive Rotation Speed4200 RPM
Memory
RAM TechnologyDDR SDRAM
Installed RAM256 MB · 1 GB · 512 MB
Installed Cache Memory1024 KB · 2048 KB
Max Supported RAM1024 MB · 1536 MB · 1280 MB · 1530 MB · 1540 MB · 1310 MB · 1576.96 MB
RAM Speed333 MHz
CD / DVD
Optical Drive Read Speed24x (CD) · 8x (DVD)
CD / DVD TypeCD-RW/DVD-ROM
Optical Drive Write Speed24x (CD)
Optical Drive ReWrite Speed24x (CD-RW)
Other Drives
Floppy Drive3.5" 1.44 MB floppy
Video
Installed Video Memory64 MB
Graphic ProcessorIntel 855GME · Intel Extreme Graphics 2
External Video Resolution1280 x 1024 · 1600 x 1200 · 1024 x 768 · 2048 x 1536
Graphic Bus InterfaceAGP
Audio
Audio Output TypeSpeaker(s) · Sound Card · Headphones
Audio Input TypeMicrophone · Integrated Microphone · Line In
Modem
Modem TypeFax / Modem · Modem
Analog Modulation ProtocolITU V.92 · ITU V.90 · K56Flex · ITU V.90, ITU V.92
Networking
Data Link ProtocolEthernet · Fast Ethernet · IEEE 802.11b · Bluetooth · Gigabit Ethernet · IEEE 802.11a · IEEE 802.11g · EtherTalk
Networking TypeBluetooth · Infrared Port · Integrated Network Card · Integrated Wireless LAN · Integrated 10/100/1000 Network Card
Battery
Battery TechnologyLithium ion
Battery Run Time10 Hour(s). · 5 Hour(s). · 3.5 Hour(s). · 7.5 Hour(s). · 12 Hour(s).
Dimensions
Depth8.3 in.
Height2 in.
Width10.6 in.
Weight3.30 lb.
Warranty
Warranty1 Year · 3 Years
World Wide WarrantyYes · Yes, Limited
Supported Models
000435165336, 000435231451, 000435305367, 000435665102, 237113U, 237157U, 237167U, 23716DU, 23716EU, 23716FU, 23717FU, 23717GU, 23718LU, 23718VU, 237197U, 2371A9U, 2371BMU, 2371BU1, 2371E5U, 2371E8U, 2371G4U, 2371GHU, 2371H8U, 2371H9U, 2371J3U, 2371J4U, 2371K3U, 2371K4U, 2371KJU, 2371KZU, 23729EU, 2372GHU, 2372KHU, 2372W4R, 2372WCL, 23828WU, 2382ECU, 2382HCU, 2382JEU, 23861CU, 23861ZU, 23865GU, 23866GU, 23866UU, 23868WU, 2386A4U, 2386BHU, 2386E9U, 2386ECU, 2386GCU, 2386HCU, 2386JBU, 2386JCU, 2386KLU more...
IBM Contact Information
Main support number1-800-IBM-4YOU / (1-800-426-4968)
Email supportaskibm@vnet.ibm.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
