20 Most Recent IBM ThinkPad 600 E Notebook Questions & Answers
it is really very easy to reset passwords for windows, but if you don't know what you are doing you might end up with only one solution and it is to reformat and re install windows!
IBM ThinkPad 600... | Answered on Apr 20, 2016
it says this when it do not have a driver for it ..or if it is not turned on from the button ...take a look on the devices buttons..sometime they are on a side of the laptop..or in front ...and it has a symbol on ...with the wireless..
IBM ThinkPad 600... | Answered on Apr 23, 2010
Press F1. At boot time.
IBM ThinkPad 600... | Answered on Apr 14, 2010
hi there, the moment you press on the power button.. keep on tapping F1 or F2 t go to bios utility.
thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Please rotate your notebook then see your fornt of your site in middle four suqare screw, Open and pull the HDD then installed New HDD.
IBM ThinkPad 600... | Answered on Dec 01, 2009
Hmm, sounds like either the speaker/speaker cable/speaker connector) developed a problem (not very likely as the parts are rather solid) or the headphone socket connector is damaged or is beginning to lose contact with the motherboard. If it's just a matter of the socket desoldering itself from the motherboard then the solution is relatively easy - you need to re-solder the socket. This involves stripping the laptop as you would need to get to the bottom of the motherboard. 600E is relatively easy to dismantle (most thinkpads are :)
Also, the headphone socket has small "switch" where if a headphone jack is inserted, it disconnects the internal speakers. In some cases the "switch" gets stuck in that position and you end up with speakers disconnected regardless of whether the jack is in or not. In any case, it's a pain to fix and involves either replacing the socket or stripping the socket.
Well-good luck :)
Hope this helps.
Raf
IBM ThinkPad 600... | Answered on Nov 05, 2009
It's asking you to go to set up to enter the correct time in the BIOS also when rebooted make sure your time zone is set correctly
IBM ThinkPad 600... | Answered on Sep 02, 2009
hi there,
better try to use CYberDVD Playerr
IBM ThinkPad 600... | Answered on Mar 14, 2009
First u check the RAM capacity.If u have Windows Vista operating system then Minimum 1GB RAM put it.
OR
Goto start-programs-Accesories-System Tools-Disk Defragmentation.There u select the drive and press Defragment Button.After all drive defragmentation,u restart the laptop.
IBM ThinkPad 600... | Answered on Dec 23, 2008
Complementary Metal Oxide Semiconductor (BIOS)
CMOS setup is the settings, for the motherboard, you get into before the PC boots into windows.
Usually by pressing F1, F2, or Delete during system startup.
IBM ThinkPad 600... | Answered on Jun 19, 2008
You need to replace the CD drive.
IBM ThinkPad 600... | Answered on Jun 14, 2008
As long as the battery is working properly it doesn't need to be changed. Laptop batteries are like any battery the more you use them the faster they wear out. If available you should always use the power supply.
IBM ThinkPad 600... | Answered on Jun 13, 2008
Try loading DVD decodeing softawre, windows media player rarely plays DVD's without help from other decoding software. Use this link, download, and try this. Then let me know.
go to your yahoo page and save it in your favorites.when you go to a motel or any other place all you have to do is go to your favorites and click the link
IBM ThinkPad 600... | Answered on Apr 18, 2008
any error like this is a dead giveaway youre cmos is dead.
Its a really common problem.
IBM ThinkPad 600... | Answered on Mar 25, 2008
when replacing ram or hdd we need to remove battery first, check by installing old ram.
IBM ThinkPad 600... | Answered on Mar 17, 2008
Format the harddrive and install an Operating System of your choice.
Good Luck.
PS: You can probably disable that memory check in your BIOS to speed up your boot time as it is not necessary.
IBM ThinkPad 600... | Answered on Feb 24, 2008
IBM ThinkPad 600 E Notebook Logo
21 questions posted
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad IBM
  • ThinkPad IBM
Most Popular Question
diskette drive
  • Computers & Internet
