20 Most Recent
IBM ThinkPad 600 Notebook Questions & Answers
Password
Set the BIOS to boot a floppy first, see if you can load a boot floppy. If
not, then you have a serious hardware problem, did you change any settings
in the BIOS? You may need to bring it to a shop for service. If you are able
to boot, then you have a hard drive problem. Check your detection settings,
and download and run a drive diagnostic tool from the hard drive
manufacturer to see if the drive has failed.
It wouldn't hurt to reseat the cabling either.
I need a free download of IBM thinkpad 600 user's
http://www-307.ibm.com/pc/support/site.wss/product.do?subcategoryind=0&familyind=50083&brandind=10&doccategoryind=0&modelind=0&doctypeind=8&validate=true&partnumberind=0&sitestyle=lenovo&template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&operatingsystemind=49979&machineind=0
I have several 600's and they all have the same
161 = CMOS configuration lost
(battery has died).
163 = CMOS error; Clock is
not updating.
192 = System fan is faulty, not plugged into the system board or the system board itself is faulty.
Whe you replaced the RTC (real time clock/BIOS battery) did you make sure that the CPU fan was working?
If it is then go back into the BIOS and reset it to defaults. Save the changes and reboot, then go back into the BIOS and try to set the time and date.
Regards.
IBM THINKPAD 600 - How to fix error codes 161 and 163
START WITH THE MACHINE OFF
HOLD and CONTINUE TO HOLD "F1"
WHILE STILL HOLDING "F1" TURN ON THE MACHINE
AND
This will go into bios, you'll get a green and white screen.
Set time and date there, save and exit.
Should work.
How do i connect to a printer
Hi Jenelle
I think we will need more information to be sure to fix this problem, like the model of the printer and are you trying to connect to it with USB cable or through network (with LAN or with wifi).
in most cases anyway make sure the wires are connected correctly (USB) and download the below link to identify and install your printer if it's not installed correctly.
press the identify now button after connecting it with USB.
HP Support Software Drivers
