20 Most Recent
Amazon Kindle Questions & Answers
Can not turn on my kindle why
Make sure it is fully charged. You can boot it by pressing and holding the on button for 40 seconds. Then try turning it on. Good luck!
How to register my kindle device
Hello
Just follow these steps To register your Kindle:
1.From Home, tap the Menu icon, and then tap Settings.
2.Tap My account.
3.Choose the Amazon account you want to use on your Kindle: If you already have an Amazon account: Tap this option. Enter your Amazon account information. Tap Register.
For any help or support visit us: Kindle Support
My kindle not open
Hello
Just follow these steps to fix this issues:
1.Press and hold, or slide and hold, the Power button for a full 40 seconds, even after the screen goes blank, then let go.
2.Press or slide the power button to restart if the device does not start up again on its own.
3.Let the device charge for 30 minutes, unplug it, and then try to restart again.
For any help or query visit us: Kindle Fire Support
Where is my menu button?
Hello
The button is located in the back next to the on button. Some Amazon Kindles come without a physical button to turn Whisper net on, but you can easily access the "power" for turning Whisper net on from directly on the device. Press the Menu button from the Home screen.
For any help or query visit us: Kindle Support
My Kindle will not charge - I have trued with various chargers I own
Hello
Just follow these steps to fix this issue:
1. Plug the device into the Kindle A/C adapter (not your computer) and let it charge for a few hours. Be sure the charging light is lit -- sometimes a drained Kindle will stop charging a few seconds after you plug it in. Unplug and replug until the light stays on steadily, then leave it alone. Most of the time you'll come back to a restored kindle. If not, go on to step 2.
2. If you still see the same Critical Battery screen after charging, unplug the USB cord, then hold the power slide to the right for at least 20 seconds.
3. Release the power slide, then immediately press and hold the Home key for another 30 - 45 seconds.
4. Once the Kindle's screen begins to flash, release the Home key. The eReader will boot to recovery mode. To continue, press and hold the R key until the screen flashes again.
5. After the device is finished rebooting, you may see the Critical Battery screen once more. If so, plug in the USB cord and wait for the Kindle to return to the Home screen.
For any help or query visit us: www Kindle Com Support
How do I download play service on a kindle fire
Hello
Just follow these steps:
Now you can continue to side load the Google apps you want to use following the same process as above. Transfer them to the Download folder on the Kindle Fire, just like you did with the first set of apps. Open ES File Explorer, open the Download folder, and tap to install the Google apps you want.
For any help or support visit us: Kindle Fire Support
How do i register on my Kindle 4.0.1?
From Home, tap the Menu Menu icon
Tap Registration.
If you already have an Amazon account: Tap this option. Enter your Amazon account information. Tap Register. Your name will appear as the Registered User when registration is complete.
If you do not have an Amazon account: Tap this option and follow the onscreen instructions to set up a new Amazon account
