20 Most Recent
Sharp Galapagos 003SH battery 2500 mAh, Black Questions & Answers
Iemi code 355656041260019 unlock mobile
What's your pone Brand and model?You can get your phone unlocked using unlock code.Unlock code is the best and safest way to unlock phone.You can get such codes from your Network service provider or any third party online vendors.If you have Blackberry phone modem then you can get unlock code at low cost from
UnBBLock.com
For, other phone models, you can get unlock code at Reasonable price from
Unlock-Zone.com here you need to specify your country,Network name to which it is locked.Then they deliver unlock code to you through mail with unlocking instructions.Using this you can unlock your phone from Network lock easily.
003sh
hi! please help me. i cannot use my sharp galapos 003sh it says it was locked because out of service area passed period of time. move to reach signal. my IMEI # is 353019043720229. my gmail adress [
[email protected]] please sir
Sharp HT-SB140 Sound Bar Internal PSU died
The Sharp HT-SB140 Sound Bar's internal PSU provides a DC output voltage of 19 volts. So you would need an external power supply that can provide a regulated DC voltage of 19V with the same or higher current rating as the original power supply.
When replacing the internal power supply with an external one, it is essential to ensure that the polarity of the output connector matches the polarity of the soundbar's internal PSU. The PW390-070 EF25 MF 1945 part number indicates that the power supply has a center-positive barrel connector. Therefore, you need to make sure that the replacement external PSU also has a center-positive connector.
It is also essential to make sure that the external power supply you choose can provide the same or higher power rating as the original internal PSU to ensure proper operation of the soundbar.
My Sharp xe-a506 register will not power on. Checked the power source and nothing.
If your Sharp XE-A506 register will not power on, there are a few possible reasons why this may be happening. First, check the power cord and ensure that it is securely plugged into both the register and a working outlet. If the cord is damaged or not properly connected, it may be preventing the register from receiving power.
If the power cord is in good condition and properly connected, the problem may be with the register itself. Try unplugging the register, waiting a few minutes, and then plugging it back in. This can sometimes reset the register and allow it to power on.
If the register still does not power on, there may be a problem with the register's internal power supply. In this case, it is best to contact Sharp customer support for assistance. They should be able to provide you with further guidance and help you troubleshoot the issue.
