20 Most Recent GE Ultrasonic 2.1 Subwoofer Computer Speakers Questions & Answers
What is the voltage for the GE Ultrasonix 2.1
THE WALL TRANSFORMER STEPA DOWN VOLTAGE FROM 120 VOLTS AC TO 12 VOLTS AC @800 MILLIAMPS
10/3/2010 4:33:54 PM • GE Ultrasonic... • Answered on Oct 03, 2010
No sound from creative t3030 2.1 speakers
the circuit board and amplifacation supply inside the sub are blow or shorted out.thus preventing any sound. the head phone jack works only because it is a bypass feature supported by the actual computer not the surround sound unit
7/24/2009 3:51:44 PM • GE Ultrasonic... • Answered on Jul 24, 2009
Computer speaker problem
Make sure the cable connected to INPUT directly connected to your sound card on GREEN plugin
Best Luck!
12/6/2008 2:52:34 PM • GE Ultrasonic... • Answered on Dec 06, 2008
Trouble code 1P:G8
I had the same issue. The fix for me was taking it apart and spraying the circuit board down with contact cleaner. My guess is that I ran a humidifier in the room and the humidity caused resistance on a resistor changing by the value.
3/18/2024 10:48:29 AM • GE Audio Players... • Answered on Mar 18, 2024
Error code 9:dd or IP:G8 in GE Clock Radio from 1990s
My GE Clock is from the Mid 1970s and still going strong. Here is the fix, which coincidentally mentions the Fixya Website. He didn't want to register to post a question with the answer.
Fixing a clock radio saying "1P:G8" or "IP:G8"? - anthrofox.org
anthrofox.org http://www.anthrofox.org > projects > ge_7_4612b GE clock radios frequently used the Texas Instruments TMS3450NL chip to operate the clock. The "1P:G8" or "IP:G8" error code is NOT documented in the datasheet ... ..
12/12/2023 4:25:29 PM • GE Audio Players... • Answered on Dec 12, 2023
How to route belts on general electric 3-5672a cassette deck
you can follow these steps:
  1. Open the cassette deck: Carefully open the cassette deck by removing any screws or clips that secure the outer casing. Be cautious not to damage any internal components or delicate parts.
  2. Observe the existing belt placement: Before removing any belts, take note of their positions and how they are routed around various pulleys, flywheels, or other components. This will serve as a reference for installing the new belts correctly.
  3. Remove and replace the belts: Gently remove the old belts, keeping track of their lengths and shapes. Measure the size and shape of the old belts or refer to any documentation that may have come with the deck to determine the appropriate replacement belts. Install the new belts one at a time, following the observed routing from step 2.
  4. Ensure proper tension: Ensure that the newly installed belts have the appropriate tension. They should be tight enough to drive the various mechanisms but not overly tight or loose. Adjust the tension if necessary.
  5. Test and adjust: After replacing the belts, reassemble the cassette deck and test its functionality. Verify that the belts drive the cassette mechanism smoothly and consistently. Make any necessary adjustments to belt tension or routing if the mechanisms do not operate correctly.
If you encounter any difficulties or are unsure about the belt routing or replacement process, it is advisable to consult a professional technician or reach out to a specialized audio repair service. They will have the expertise and knowledge to handle the specific requirements of your General Electric 3-5672A cassette deck and ensure proper belt routing.
7/15/2023 1:41:31 PM • GE Audio Players... • Answered on Jul 15, 2023
GE COLOR TELEVISION AM/ FM RADIO SPACEMAKER no radio connection.
If you are experiencing issues with your GE Color Television AM/FM Radio Spacemaker where you are not getting any radio signal, it could be caused by a few different issues. Here are a few things you can check:
  1. Check the antenna connections: Make sure that the antenna connections are tight and that there are no loose or damaged wires.
  2. Check the antenna: Make sure that the antenna is properly positioned and that it is not damaged.
  3. Check the tuner: Make sure that the tuner is functioning properly and that it is not damaged.
  4. Check the audio settings: Make sure that the audio settings are correctly configured.
  5. Check the audio output: Make sure that the audio output is not muted or turned down.
  6. Check the power supply: Make sure that the power supply is providing the correct voltage and that it is not damaged.
  7. Check the signal: Make sure that the signal strength is strong enough to receive radio signal.
If none of these steps resolve the issue, I would recommend contacting GE's customer support for further assistance. They may be able to provide additional troubleshooting steps or may recommend a qualified technician to repair the unit.
1/14/2023 10:22:41 PM • GE Audio Players... • Answered on Jan 14, 2023
Can you hook up a ge 50 graphic equalizer booster to a car amplifier
Any stereo or car store can tell u
10/19/2021 4:06:43 AM • GE Audio Players... • Answered on Oct 19, 2021
Model No 7 - 4897A. The alarm times are set but alarm doesn't sound?
I was hoping I could find a manual, but it looks like an older clock radio, probably the same as mine! Some have a second step that after setting the alarm, you have to press a button or slide a switch. Mine has Off, Radio, Alarm On (sounder only), and Alarm by Music. https://www.google.com/search?q=Model+No+7+-+4897A+manual ..
9/10/2021 8:28:04 PM • GE Audio Players... • Answered on Sep 10, 2021
Need to learn how to set the time and alarm for GE 7-4852A.
To set the time, make sure that the radio is Off; use the left-most button if the radio is on. Use the Fast Forward, Forward and Reverse buttons to get to the current time. These buttons are on the right of the snooze button. The AM indicator will light when the current time is between midnight and noon. To set the alarm, move the switch for that alarm to the Alarm Set position. Then use the same fast forward, forward and reverse buttons to reach the time for your wake alarm. The manual for the GE 7-1825 is available at ManualsLib: https://www.manualslib.com/manual/138580/Ge-7-4825.html . It's easier to read when you download the PDF. That requires dealing with Captcha. The suffix indicates the clock radio version; the manual is the same for units. I hope this helps. Cindy Wells
12/9/2020 2:39:50 AM • GE Audio Players... • Answered on Dec 09, 2020
I NEED A MANUAL FOR A GE CLOCK RADIO #7-4612A,PLEASE RESPOND ASAP.
May be the manual in this open box sale 7-4624 shown in picture that may be compatible yours (may be a and b versions of that radio for sale) that you could request from the seller. (FIXYA does not sell radios or manuals.) I do not know if a seller would be willing to provide you a copy of a manual for free or at cost.Picture of instructions in box:https://www.ebay.com/i/264682947591?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=264682947591&targetid=885020184850&device=c&mktype=pla&googleloc=9008155&poi=&campaignid=9423618435&mkgroupid=96387797275&rlsatarget=pla-885020184850&abcId=1141016&merchantid=6296724&gclid=CjwKCAjw4871BRAjEiwAbxXi2y9U0o9VvJF_jV3wZbiOUHj3dRmezMYLLKxnou93c9w9v_X8r0RC4xoCaNcQAvD_BwEhttps://www.ebay.com/i/264682947591?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=264682947591&targetid=885020184850&device=c&mktype=pla&googleloc=9008155&poi=&campaignid=9423618435&mkgroupid=96387797275&rlsatarget=pla-885020184850&abcId=1141016&merchantid=6296724&gclid=CjwKCAjw4871BRAjEiwAbxXi2y9U0o9VvJF_jV3wZbiOUHj3dRmezMYLLKxnou93c9w9v_X8r0RC4xoCaNcQAvD_BwE
5/7/2020 10:46:27 PM • GE Audio Players... • Answered on May 07, 2020
3answers
Set clock on GE 422-2195 alarm
https://www.youtube.com/watch?v=7KRQOjhET-E https://www.youtube.com/watch?v=JQIYMVRqhPA How do I set the Time and Date for my Interlogix Concord Panel? From the keypad, enter user programming by pressing 9 and the master code. Press # to get to the time set-up. Enter the correct hour (00-23) and minute (00-59). https://zionssecurity.com/faq-security/ge-interlogix-concord-panel-questionsfrequently-asked/
4/27/2020 7:00:51 PM • GE Audio Players... • Answered on Apr 27, 2020
2answers
Have a general electric clock radio model no. 7-4613a how do I set wake and sleep settings
Hi Larry, I sent you the link to download the user manual of a GE 7-4812, which is similar to your GE 7-4613, follow the steps indicated there for the selection of the alarm and you can enjoy your GE Regards Franco Dosil Hola Larry, te envio el link para que descargues el manual de usuario de un GE 7-4812, que es similar a tu GE 7-4613, sigue los pasos indicados ahi para la seleccion de la alarma y podras disfrutar de tu GE Saludos Franco Dosil https://www.manualslib.com/manual/138579/Ge-7-4812.html https://i.ebayimg.com/images/g/vsAAAOSwDX9b50fQ/s-l300.jpg
10/4/2019 6:14:01 PM • GE Audio Players... • Answered on Oct 04, 2019
2answers
How does GE clock radio 7-4612-a work on battery?
Battery is just power backup.
10/4/2019 4:35:56 PM • GE Audio Players... • Answered on Oct 04, 2019
6 questions posted
Top GE Audio Players & Recorders Experts
Rob Hill
Rob Hill
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • GE Audio Players & Recorders
Most Popular Question
voltage ge ultrasonix 2 1
  • Audio Players & Recorders
