FixYa.com
IBM xSeries 346 Server
All Products > IBM > Servers
Problems with IBM xSeries 346 Server?
Troubleshooting and Support
Solved Problems for IBM xSeries 346 Server RSS Feed Post a New Problem
Yahoo messenger sign in
Yahoo messenger would not let me sign in so I uninstalled and installed and newer version and still cant sign in
2 Solutions
Window closing Problem
whenever i close some of websites like rediff, yahoo etc etc after using it a window comes writing the following:...
2 Solutions
problem booting
hi there , i cant just power on my server .when i click the power button fan moves for a second and then back off.what...
1 Solution
Client Machine Won't Boot so I powered on...
Client Machine Won't Boot so I powered on the client machine but all I see is an incrementing counter, any suggestions?
1 Solution
Slow download
My download is very slow.
1 Solution
blutoohth
i have sky broadband are you compatable!. What devices do i need to set up my second PC to my wireless broadband?????
1 Solution
dell precision 670 workstation
i already have 4gb of ram ECC REG dual channel kit, but when i tried to put 4 more it doesn't work and it wouldn't login...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for IBM xSeries 346 Server RSS Feed Post a New Problem
server doesnt boot
I had a problem with one of the hard disks of an IBM server xSeries 346. Through the diagnostics cd, I saw that one of...
Post a Solution
xseries 346 wont boot
I have a IBM xSeries 346. It was showing 1 hard disk defunct. I boot through the diagnose cd and tried to rebuild. It...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC, Unix · PC
Operating SystemMicrosoft® Windows 2003 Server Edition
Form FactorRack-Mountable 2U · Rack-Mountable
ProcessorXeon 3 GHz · Xeon 3.2 GHz · Xeon 2.8 GHz · Xeon 3.6 GHz · Xeon 3.4 GHz
Installed Memory2 GB (DDR SDRAM) · 1024 MB (DDR SDRAM)
Processors Qty.1
ChipsetIntel E7520
Processor
Processor TypeXeon
Processor Speed3 GHz · 3.2 GHz · 2.8 GHz · 3.4 GHz · 3.6 GHz
Processor ManufacturerIntel
Processor UpgradabilityUpgradable
Installed Qty1
Socket TypeSocket 604
Max Supported Qty2
Technical Features
Expansion SlotsPCI-X 64 Bit (100 MHz) Low Profile x 2, PCI-X 64 Bit (133/100/66 MHz) x 2
Integrated Input/Output PortsUSB 2.0 x 3, RJ45 Lan Port x 2, Serial Port x 1, PS/2 Mouse x 1, PS/2 Keyboard x 1 · USB 2.0 x 3, RJ45 Lan Port x 2, Serial Port x 1, PS/2 Mouse x 1, PS/2 Keyboard x 1, Floppy Port x 1
Storage Controller Type(s)SCSI · IDE / EIDE · DMA/ATA-100 (Ultra) x 1, SCSI Ultra320 (Dual Channel) x 1 · SCSI Ultra320 (Dual Channel) x 1 · DMA/ATA-100 (Ultra) x 2, SCSI Ultra320 (Dual Channel) x 1
Security FeaturesPower-On Password, Administrator Password, Boot Sequence Control · Selectable Boot, Unattended Start-up, Power-On Password, Administrator Password
Hot Swap ComponentsPower Supply, Hard Disk Drives · Hard Disk Drives · Power Supply, Cooling Fans, Hard Disk Drives
Motherboard
Video Output InterfacePCI · PCI 64
Memory
RAM TechnologyDDR SDRAM · DDR2 SDRAM
Installed RAM2 GB · 512 MB · 1024 MB
Maximum RAM16 GB
Installed L2 Cache Memory2 MB · 1 MB
Installed Video Memory16 MB
Supported RAM Speeds400 MHz
Number of Memory Slots8 x 240 Pin DIMMs
Hard Drive
Hard Drive Capacity220.2 GB · 1272.8 GB
Hard Drive InterfaceSCSI Ultra320
RAID SupportRAID 0, RAID 1 · RAID 0, RAID 1, RAID 10 · RAID 0, RAID 1, RAID 10, RAID 5, RAID 50, RAID 5EE · RAID 0, RAID 1, RAID 10, RAID 5, RAID 50, RAID 1E, RAID 00, RAID 5EE
Maximum Storage Capacity876 GB · 880.8 GB
CD / DVD
Read Speed24x (CD), 8x (DVD) · 8x (DVD), 24x (CD) · 8x (DVD)
CD / DVD TypeCD-ROM · DVD-ROM
Other Drives
Floppy Type3.5" 1.44 MB floppy
Audio / Video
Max. Video Resolution1600 x 1200 · 2048 x 1536
Networking
Data Link ProtocolEthernet, Fast Ethernet, Gigabit Ethernet · Gigabit Ethernet
Networking Type10/100/1000 Network Adapter x 1 · 10/100/1000 Network Adapters x 2
Other Features
Expansion Bays6 x 1" Hot-swap Ultra320/160 SCSI, 1 x 5.25" (External Access), 1 x 3.5" (External Access) · 6 x 1" Hot-swap Ultra320/160 SCSI, 1 x 5.25" External Slim Line (1/6H)
Other FeaturesHyper Thread Technology Ready, Dual Channel Memory Architecture
Power ConfigurationsWake On LAN Header
Power Supply TypeHot plug · Hot Plug With Optional 1+1 Redundancy · Hot Plug, Redundant
Power Supply Output625 Watt
Regulatory ApprovalFCC Class A · CSA, UL, FCC Class B
System ManagementIntelligent Platform Management Interface (IPMI)
Dimensions
Depth27.5 in.
Height3.36 in.
Width17.5 in.
Weight46 lb.
Warranty
Warranty3 Years
Supported Models
884001u, 88400EU, 884011u, 884017U, 884021u, 884031u, 884032u, 884041u, 884042u, 8840E1U
IBM Contact Information
Main support number1-800-IBM-4YOU / (1-800-426-4968)
Email supportaskibm@vnet.ibm.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
