20 Most Recent
AVC 12v dc 0.7a 70x15mm 3-wire fan da07015b12u-far Questions & Answers
Needwiring diagram for a avc fan da12025b12l
I have two articles on this, neither of which correspond to what I said in another answer.
Dell use or used to use a non standard pin out (so it will depend was made by AVC especially for Dells)
In the standard pin out the black wire is 0V, the next often yellow is +V (12V for your fan) the third one is speed sense, and the final one is speed control (you search the internet under 4-pin fan pin-out to be more confident.)
Two article are
http://www.formfactors.org/developer%5Cspecs%5CREV1_2_Public.pdf (section 4.1.6)
and
http://www.setiusa.us/showthread.php?2480-PWM-Fan-Pinouts-Industry-Standard-amp-Dell-configurations the picture drom the second article I reproduce (without permission).
To be certain consult your m/b manual which should all the pin assignmens on your m/b, or you can try to measure the voltage between 0V and the second pin to verify that it is +12V in your case (it may be lower or as high as 13.2V)
Cpu fan's
One of the best sources I've found is
www.mwave.com. You can check out their fans at:
http://www.mwave.com/mwave/dosearch_v2.asp?scriteria=cooling%20fan&bop=and&bbp=and&catpromotename=%filename%client-url%
I've bought from them for years and always had good results. If nothing else, you can find the type fan you need and then try and find it locally.
Good luck, and please let me know how it works out!
Como cancelar el winter driver
Question translated to English
Solo hablamos ingl?s en el sitio web norteamericano. Lamentablemente no tenemos idea de qui?n es este conductor de invierno. Por favor danos m?s informaci?n para ayudarte mejor. Es un problema de seguro de autom?vil, debe comunicarse directamente con la compa??a de seguros.
ENGLISH@
We only speak English on the North American website. Unfortunately we have no idea who this winter driver is. Please give us some more information to help you better. It is is a car insurance issue, you need to contact the insurance company direct.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
