20 Most Recent IBM Infoprint 1140 Laser Printer Questions & Answers
Try at www.ebay.com . Choose computer and aceessories.
IBM Infoprint... | Answered on Oct 23, 2012
Hi
Open the internet explore and type the previous and press enter.exp 192.168.1.10, go to the network setting and set the ip address whatever u want, and save and restart your printer.
IBM Infoprint... | Answered on May 13, 2011
To disable the operator panel menus so that changes cannot be made to the printer default settings: 1 Turn the printer off. Note: Disabling the operator panel menus does not prevent access to the Job Menu or to Print and Hold functionality. 2 Press and hold Select and Return and turn the printer on. 3 Release the buttons when you see Performing Self Test. Config Menu appears on the first line of the display. 4 Press Menu until you see Panel Menus, and then press Select. Disable appears on the second line of the display. 5 Press Select. Locking Menus appears briefly. 6 Press Menu until you see Exit Config Menus, and then press Select. The menus are disabled. If you press Menu, the message Menus Disabled appears. To enable the menus: 1 Repeat steps 1 through 4. 2 Press Menu until you see Enable. 3 Continue with steps 5 and 6.
IBM Infoprint... | Answered on May 18, 2010
Hi friend,
This is posiblem,follw the given below path and select
1- select the property of printer
2-go to the device settings
3-form to try assignment
4-select the both "letter"
good luck,
Thanks,
IBM Infoprint... | Answered on Jan 30, 2010
here is the link download form it
IBM Infoprint... | Answered on Nov 17, 2009
when you go to the menu of the printer is the paper TYPE set correctly?
tray 2 should be letter ( if using plain paper)
tray 3 legal, label etc...
and tray 1 should be any
IBM Infoprint... | Answered on Oct 19, 2007
Two things. Multipart forms have a film on the top copy. Change the ribbon to another brand. Some work better than other. Probably if it printing some on the top copy, and it works on regular paper.
If it does work on regular paper its the ribbon may be old or change to different brand.
A work around is to use eraser on the form where you going to print. This will the remove the film, and allow to type there.
IBM Office... | Answered on Mar 02, 2019
Best probability is the power supply inside the machine has failed. Could be internal fuse no usually. This is generally a major repair.
Is there any electric motor repair shops near you? if not try this one:
http://www.reselectricmotors.com/
if not that one the people at koontz-wagner are usually able to help me.
https://www.koontz-wagner.com/
IBM Office... | Answered on Feb 14, 2019
If you have checked the ribbon, and see that it is moving by looking at the letters on it. You may be in stencil postion.
Just below the ribbon there is an r and and s Push the r button and try it.
IBM Office... | Answered on Feb 02, 2019
One it could be a bad ribbon. the other is a bad print hammer, or is failing, there is platic cap on the selenoid that cracks after years.
Needs replaced most likely, Or the selenoid plunger is gummed up.
IBM Infoprint 1140 Laser Printer Logo
Popular Tags
16 questions posted
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • IBM Office Equipment & Supplies
Most Popular Question
cannot change paper size trays 1 2 tray
  • Office Equipment & Supplies
