20 Most Recent IBM Infoprint 2085 All-In-One Laser Printer Questions & Answers
sc495 is a problem with the toner supply system. It may be as simple as a clump of toner clogging up one of the hoses, or it could be a bad toner end sensor or bad motor failing to transport the toner.
IBM Infoprint... | Answered on Aug 24, 2011
Turn off, remove print wheel, turn on, turn off, reinstall print wheel, turn on. Make sure PROPORTIONAL SPACING is not selected.
IBM Office... | Answered Yesterday
Two things. Multipart forms have a film on the top copy. Change the ribbon to another brand. Some work better than other. Probably if it printing some on the top copy, and it works on regular paper.
If it does work on regular paper its the ribbon may be old or change to different brand.
A work around is to use eraser on the form where you going to print. This will the remove the film, and allow to type there.
IBM Office... | Answered on Mar 02, 2019
Best probability is the power supply inside the machine has failed. Could be internal fuse no usually. This is generally a major repair.
Is there any electric motor repair shops near you? if not try this one:
http://www.reselectricmotors.com/
if not that one the people at koontz-wagner are usually able to help me.
https://www.koontz-wagner.com/
IBM Office... | Answered on Feb 14, 2019
If you have checked the ribbon, and see that it is moving by looking at the letters on it. You may be in stencil postion.
Just below the ribbon there is an r and and s Push the r button and try it.
IBM Office... | Answered on Feb 02, 2019
One it could be a bad ribbon. the other is a bad print hammer, or is failing, there is platic cap on the selenoid that cracks after years.
Needs replaced most likely, Or the selenoid plunger is gummed up.
Most likely the power supply has failed. Could be a fuse, both are internal. Fuse not likely.
IBM Office... | Answered on Jan 19, 2019
If all the lights flash then you type and it goes away, means batteries need to be changed.
IBM Office... | Answered on Jan 18, 2019
Make sure its plugged in. Yup. Might be a fuse or Power supply is dead. these are all internal.
IBM Infoprint 2085 All-In-One Laser Printer Logo
2 questions posted
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • IBM Office Equipment & Supplies
Most Popular Question
sc495
  • Office Equipment & Supplies
