IBM ThinkCentre A50 PC Desktop
Problems with IBM ThinkCentre A50 PC Desktop?
Troubleshooting and Support
Solved Problems for IBM ThinkCentre A50 PC Desktop RSS Feed Post a New Problem
Seeing Red!
Hi Guys, I use Windows XP Home Version 2002 I experience visual interference on certain sites ie: Hostgator &...
1 Solution
Installing RAM
Hi, I have an HP media center PC, the M1000 series, I need to install more RAM, but I can't see where it goes.
1 Solution
Soltek E3401M
I'm searching the drivers of this computer for XP Pro. Can you help me ? Where can I find IT ??? Thank you
1 Solution
screen saver
it doesn't work. i have tried to change my screen saver but nothing.
1 Solution
I need an update for my pheonix bios
I pieced together this pc from older ones I upgraded or just generally toyed around with after my last pc got stollen...
1 Solution
my PC hangs sometimes when I connect my...
my PC hangs sometimes when I connect my USB device into USB.
1 Solution
memory
My memory is not right. I have two memory sticks in and they are 256 so I should have 512 but it is only saying 504....
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Operating SystemMicrosoft Windows XP Home Edition · Microsoft Windows XP Professional
Form FactorUltra Small Form Factor · Tower · Desktop Slimline · Small Form Factor · Desktop
ProcessorIntel Pentium 4 2.4 GHz · Intel Pentium 4 2.6 GHz · Intel Pentium 4 3 GHz · Intel Pentium 4 3.2 GHz · Intel Pentium 4 2.8 GHz · Intel Celeron 2.4 GHz · Intel Celeron D 2.8 GHz · Intel Celeron D 2.53 GHz · Intel Celeron D 2.66 GHz · Intel Celeron 2.66 GHz · Intel Celeron D 2.93 GHz · Intel Celeron 2.53 GHz · Intel Celeron 2.6 GHz
Installed Memory256 MB (DDR SDRAM) · 512 MB (DDR SDRAM) · 128 MB (DDR SDRAM)
Recommended UseCorporate Business, Small Business · Home Use
ChipsetIntel 865G · Intel 865GV
Processor
Processor TypeIntel Celeron D · Intel Pentium 4 · Intel Celeron
Processor Speed2.53 GHz · 2.4 GHz · 2.6 GHz · 3 GHz · 3.2 GHz · 2.66 GHz · 2.8 GHz · 2.93 GHz
Processor ManufacturerIntel
Processor UpgradabilityUpgradable
Max Processors Qty.1
Installed Qty1
Socket TypeSocket 478
Processor Number330 · 540 · 530 · 520 · 335 · 325 · 340
Motherboard
Bus Speed400 MHz · 800 MHz · 533 MHz
Video Output InterfaceAGP · PCI · AGP 8x · Direct AGP
Memory
RAM TechnologyDDR SDRAM
Installed RAM256 MB · 512 MB · 128 MB
Installed Cache Memory512 KB · 1 MB · 128 KB · 256 KB
Max Supported RAM2 GB · 4 GB
Installed Video Memory64 MB
Supported RAM Speeds400 MHz · 266 MHz · 333 MHz
Number of Memory Slots2 x DIMMs · 2 x 184 Pin DIMMs · 4 x 184 Pin DIMMs
Technical Features
Expansion SlotsPCI x 3 · AGP x8 x 1 · PCI x 1 · PCI x 2 · PCI x 4
Integrated Input/Output PortsSerial Port x 2 · Serial Port x 1 · PS/2 Mouse x 1 · PS/2 Keyboard x 1 · Parallel Port (ECP/EPP/SPP) x 1 · USB 2.0 x 6 · RJ45 Lan Port x 1 · Floppy Port x 1 · USB 2.0 x 8
Expansion Bays2 x 3.5" (External Access) · 2 x 5.25" (External Access) · 1 x 5.25" (External Access) · 1 x 3.5" (Internal Access) · 1 x 3.5" (External Access) · 2 x 5.25" Half-Height (External Access) · 1 x 3.5" Third-Height (External Access) · 1 x 3.5" Third-Height (Internal Access) · 1 x 5.25" Half-Height (External Access) · 2 x 3.5" Third-Height (External Access) · 1 x 5.25" External Slim Line (1/6H)
Other FeaturesHyper Thread Technology Ready · Dual Channel Memory Architecture
Security FeaturesBoot Sequence Control · Boot Without Keyboard or Mouse · Diskette I/O Control · Parallel Port I/O Control · U-Bolt Anchoring Feature · Serial Port I/O Control · Hard drive I/O control · Diskette Boot Inhibit · Hardfile I/O Control · USB Port Control · IBM Security Slot · Slot For Cable Lock · Power-On Password · Administrator Password · Setup Password · Kensigton Lock Slot
Power ConfigurationsACPI/APM Power Management · Wake On LAN Header · Wakeup from Keyboard/Mouse · Suspend to RAM
Hard Drive
Controller TypeEIDE · IDE · DMA/ATA-100 (Ultra) · Serial ATA
Hard Drive Capacity40 GB · 120 GB · 800 GB · 80 GB
Hard Drive InterfaceEIDE · IDE · DMA/ATA-100 (Ultra)
Hard Drive Rotation Speed7,200 RPM
CD / DVD
Optical Drive TypeCD-ROM · CD-RW · DVD-ROM · CD-RW/DVD-ROM (Combo)
Optical Drive Read Speed16x (DVD) · 48x (CD) · 24x (CD) · 8x (DVD)
Optical Drive Write Speed24x (CD-R) · 48x (CD-R)
Optical Drive ReWrite Speed24x (CD-RW) · 32x (CD-RW)
Other Drives
Floppy Drive3.5" 1.44 MB floppy
Audio / Video
Audio Output TypeSound Card · Headphones · Line Out
Max. Video Resolution2048 x 1536 · 1920 x 1200
Graphic ProcessorIntel Extreme Graphic 2 · NVIDIA GeForce4 MX440
Audio InputMicrophone Jack · 2 x Line In · 1 x Line In
Video Out Ports15 Pin D-Sub VGA port x 1
Integrated AudioAC'97 Audio Codec · AD1981B Codec
Modem
Modem TypeFax / Modem
Networking
Data Link ProtocolEthernet · Fast Ethernet · Gigabit Ethernet
Networking TypeNetwork Adapter · Integrated 10/100 Network Card · Integrated 10/100/1000 Network Card
Warranty
Warranty1 Year · 3 Years
Dimensions
Depth16 in.
Height3.35 in.
Width3.5 in.
Weight20 lb.
Supported Models
000435337511, 000435337603, 000435337658, 000435337689, 000435343628, 000435394989, 000435438201, 808424U, 808441U, 8084D7U, 808521U, 808532U, 8085B1U, 8085C6UCTO, 8085C6UCTO1, 8085E1U, 8085E1U08, 8085E4U, 808911U, 808921U, 808922U, 808932U, 809011U, 809012U, 809021U, 809022U, 809032U, 8090A1U, 8090A2U, 8090A3U, 814711U, 814713U, 814721U, 814723U, 814724U, 814725U, 8147CBU08, 8147CFU08, 814812U, 814815U, 814816U, 814821U, 814822U, 814825U, 814826U, 814833U, 814835U, 814842U, 8148A1U, 8148A4U, 8148B2U more...
IBM Contact Information
Main support number1-800-IBM-4YOU / (1-800-426-4968)
Email supportaskibm@vnet.ibm.com
Sponsored Links
Loading problems.
Top Experts
Ask Me
s4u311 Wiz
1 solutions
Ask Me
pincer Wiz
1 solutions
Ask Me
map9966 Guru
2 solutions
Repair Service
Find PC Desktop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
