FixYa.com
Motorola WR850GP Router
All Products > Motorola > Routers
Problems with Motorola WR850GP Router?
Troubleshooting and Support
Solved Problems for Motorola WR850GP Router RSS Feed Post a New Problem
wireless router
hi i need to have ports open on router to be able to use slingbox on my laptop. can u you help me? plzzzzzzzzzzzzzzzz
1 Solution
I forgot my password.
Ok, so the last time I messed with the router was about a year ago, and I seem to have forgoten the password that I set...
1 Solution
What is my passkey security codes on my...
Hello! My name is James. I'm trying to access my laptop wireless but it required me to know my passkey codes on my...
1 Solution
XBox 360 not compatible with Motorola...
can't get xbox 360 to connect to xbox live, the connection test fails at MTU, wired or wireless. My WR850G (not on...
1 Solution
Forgot my password.
1 Solution
network parental control
Is there a way to use my Motorola WR850GP for parental control of the whole home network? The parental control page of...
1 Solution
open messenger ports
how do i get into the manager for the router firewall? need to unblock the messenger ports. Thanks!
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Motorola WR850GP Router RSS Feed Post a New Problem
Incapable of FTP w/ Router
Every time I try to FTP upload to my website, I get 0 byte files...and generally uploading hangs up, even though I can...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
ConnectivityWireless
FunctionalitiesWireless Access Point, VPN Pass-Thru, DHCP Server
Interfaces
Built-In4-port Built-In Switch
LAN Interfaces10/100 Base-T
WAN Interfaces1 x 10/100 Base-T
Standards and Protocols
Management ProtocolWeb Based / HTTP, TFTP
StandardsIEEE 802.3 Ethernet, IEEE 802.3u Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Routing ProtocolsRIP Version 1, RIP Version 2, Static Routing
ProtocolsDHCP, IP, PPPoE, TCP, UDP
Wireless
802.11b Data Rates11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps
802.11g Data Rates54 Mbps, 48 Mbps, 36 Mbps, 24 Mbps, 12 Mbps, 9 Mbps, 6 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps
ModulationDSSS, CCK, DBPSK, DQPSK, OFDM, BPSK, QPSK, 16QAM, 64QAM
802.11b/g Indoor Range100 meter
802.11b/g Outdoor Range400 meter
Antenna TypeDetachable Antenna x 1
Security
WEP Encryption40 bit (=64 bit), 128 bit
Other Features
Additional FeaturesAuto Crossover (MDI/MDI-X)
LED IndicatorsPower, WAN, WLAN (Wireless LAN), Link (Per Port)
Dimensions
Depth5.78 in.
Height.98 in.
Width5.95 in.
Weight.74 lb.
Warranty
Warranty2 Years
Motorola Contact Information
Main support number1-866-BUY-MOTO
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
