FixYa.com
Motorola Wireless G Broadband Router
All Products > Motorola > Routers
Problems with Motorola Wireless G Broadband Router?
Troubleshooting and Support
Solved Problems for Motorola Wireless G Broadband Router RSS Feed Post a New Problem
lafe1432 need help again sorry
Hi i play a game called warcraft 3 frozenthrone and i play battle.net its online and when i host a game nobody cant join...
1 Solution
wireless router not connecting to internet
I have used this same router with this laptop in the past, but one night it just stopped working. I tested my desktop...
1 Solution
cant get motorola wr850g to see time...
my computer sees the motorola and it says i'm connected to it but modem connection to modem flashes red, when i click on...
1 Solution
Password/security key
My son got a new laptop for graduation and I need the router password/security so that he can set it up.
1 Solution
I cant figure out my password
When i go to my Default Gateway two Boxes pop up, 1 for a username and another for Password. After various internet...
STAFF 1 Solution
WR850G router need setup CD
I inherited a new router from my daughter. it has no cd or power supply. The P/S I can get a universal rom radio Shack...
1 Solution
Existing Hex key
Where do I find my hex key code? I bought a new laptop for my son and need to connect it but cannot find out where i...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Motorola Wireless G Broadband Router RSS Feed Post a New Problem
MOTOROLA WIRELESS BROADBAND ROUTER 850G
I HAVE DOWNLOADED THE DRIVERS THAT YOU HAVE SPECEFIED IN...
Post a Solution
i have time warner cable modem, my mac (tiger 10.4) airport found the motorola wr850g signal. with wireless and/or...
Post a Solution
network switch
used my wr850g fine on time warner a year ago...now with comcast, i get a red modem light and it won't work as even a...
Post a Solution
Help!!!
How do i connect my vonage system to work with my motorola wireless G broadband router. IT will not connect to the...
Post a Solution
netopia 334nwg-006 .what is the best...
I am looking to buy a wireless card to work with the netopia 3347nwg-006.I have an desktop computer that runs on windows...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
ConnectivityWireless
FunctionalitiesWireless Access Point, VPN Pass-Thru, Firewall, DHCP Server
Interfaces
Built-In4-port Built-In Switch
LAN Interfaces10/100 Base-T
WAN Interfaces1 x 10/100 Base-T
Standards and Protocols
Management ProtocolWeb Based / HTTP
StandardsIEEE 802.3 Ethernet, IEEE 802.3u Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Routing ProtocolsRIP Version 1, RIP Version 2, Static Routing
ProtocolsDHCP, IP, PPPoE, TCP, UDP
Wireless
802.11b Data Rates11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps
802.11g Data Rates54 Mbps, 48 Mbps, 36 Mbps, 24 Mbps, 12 Mbps, 9 Mbps, 6 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps
ModulationDSSS, CCK, DBPSK, DQPSK, OFDM, BPSK, QPSK, 16QAM, 64QAM
802.11b/g Indoor Range99.97 meter
802.11b/g Outdoor Range399.9 meter
Antenna TypeDetachable Antenna x 1
Security
WEP Encryption40 bit (=64 bit), 128 bit
SecurityIPSec Pass-Thru, PPTP Pass-Thru, DMZ, NAT, MAC Address Filtering, IP Filtering
Wireless SecurityWEP, WPA, TKIP, AES, 802.1x
Other Features
Additional FeaturesAuto Crossover (MDI/MDI-X)
LED IndicatorsPower, WLAN (Wireless LAN), Link (Per Port)
Dimensions
Depth5.95 in.
Height0.98 in.
Width5.78 in.
Weight0.74 lb.
Warranty
Warranty2 Years
Motorola Contact Information
Main support number1-866-BUY-MOTO
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
