20 Most Recent
Sony Ericsson Xperia X12 Arc LT15i Questions & Answers
Unlock lt15i sony ericson
You can unlock your Sony Ericson LT15i form Network lock by using unlock code.To get unlock code visit
Theunlockarena.com here you need to specify your country,IMEI number of your phone,Network provider to which it is locked. Then they deliver unlock code to you through mail.By using this you can unlock your mobile easily.
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off.
These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
Sony cfd-s70 Will Not Read CDs
There are a few possible causes for a Sony CFD-S70 CD player not reading CDs. Some possible issues include:
- Dirty or damaged CD: Make sure the CD is clean and free of scratches or damage.
- Dirty lens: The lens that reads the CD may be dirty or dusty. A cleaning disc can be used to clean the lens, or you can use a soft, dry cloth to gently wipe it clean.
- Faulty lens: If the lens is faulty, it may need to be replaced.
- Faulty CD mechanism: If the CD mechanism is not working properly, it may need to be repaired or replaced.
- Power Supply Problem: Make sure the power supply is connected and the power outlet is working.
- Firmware issue: A firmware issue could prevent the CD player from reading CDs. You should check the Sony website to see if there are any firmware updates available for your specific model.
If the problem persists after trying these suggestions, it is recommended to take the device to a professional repair service or the nearest Sony Service center.
Sony TRV 740 E Fehlercode C:31:40
Der Fehlercode C:31:40 bei Sony Camcordern deutet auf ein Problem mit dem Motor des Kassettenfachs hin. Es kann sein, dass der Motor blockiert ist oder dass es ein Problem mit den Sensoren gibt, die den Status des Kassettenfachs ?berwachen. Um das Problem zu beheben, k?nnen Sie folgende Schritte ausprobieren:
- Entfernen Sie die Batterie und das Netzkabel des Camcorders und lassen Sie das Ger?t f?r einige Minuten ausgeschaltet.
- ?berpr?fen Sie das Kassettenfach auf lose Teile oder Fremdk?rper, die m?glicherweise blockieren k?nnten.
- Versuchen Sie, das Kassettenfach vorsichtig zu schlie?en und zu ?ffnen, um zu sehen, ob dies das Problem l?st.
- Wenn das Problem weiterhin besteht, k?nnen Sie versuchen, das Kassettenfach mit Druckluft zu reinigen, um m?gliche Blockaden zu entfernen.
- Wenn alle diese Schritte fehlschlagen, kann es ein mechanisches oder elektronisches Problem sein, das eine Reparatur durch einen qualifizierten Techniker erfordert.
Es ist auch m?glich, dass das Problem durch eine defekte Cassette verursacht wird. Wenn m?glich, versuchen Sie, eine andere Cassette auszuprobieren, um zu sehen, ob dies das Problem l?st. Wenn das Problem weiterhin besteht, liegt es h?chstwahrscheinlich am Camcorder selbst.
Sony Playstation 3. Infamous intro doesn't load
- Restart the console: Sometimes, restarting the console can resolve software issues and help the game load properly.
- Check for updates: Make sure you have the latest firmware installed on your PlayStation 3, which can be done by navigating to the "Settings" menu and then to "System Update".
- Check the game disc: Make sure the disc is clean and free of scratches or damage. If the disc is damaged, it may need to be replaced.
- Reinstall the game: Try uninstalling the game and reinstalling it from the disc. This can help resolve any corrupt data that may be causing the issue.
- Try a different game: If the issue persists, try playing a different game to see if it's specific to Infamous 2 or if it's a general issue with the console.
Have a sony nwz a818 but windows 10 wont recognise it. what windows will it work with ie windows 7/8/vista have a unused windows 10 which i can downgrade to any of these windows operating systems
If your Sony NWZ A818 is not being recognized by Windows 10, it may be an issue with the device driver. The device driver is software that allows the operating system to communicate with the hardware.
Here are a few steps you can try to resolve the issue:
- Connect the Sony NW on a different USB port on your computer, sometimes it may be a problem with the USB port.
- Check for Windows updates and install any updates that are available.
- Uninstall and reinstall the device driver.
- Try connecting the device to another computer to see if it is recognized.
- Downgrade your operating system to a version that has been tested and confirmed to work with your device, such as Windows 7, 8 or Vista.
It's important to note that some devices may not be compatible with newer operating systems and may require a downgrade to an older version of the operating system. It is always recommended to check the device's official website or the manual for information on which operating systems are supported and compatible.
If you decide to downgrade your operating system, it's important to make sure that you have a backup of your important files and data and that you follow the instructions provided by Microsoft or your computer manufacturer to ensure a successful downgrade.
