20 Most Recent
Motorola mc3190-gl4h24e0a - Mc3190-g, Wlan 802.11 Abg, Questions & Answers
The MC 3300 scanner is frozen on a white background that has a blue motorola symbol. and says MC33X series
If your MC3300 scanner is frozen on a white background with a blue Motorola symbol and says MC33X series, you can try a soft reset to see if that resolves the issue. To do this, follow these steps:
- Hold down the power button until the scanner turns off.
- Wait a few seconds, then press the power button again to turn the scanner back on.
If the scanner is still frozen after attempting a soft reset, you may need to perform a factory reset. Please note that performing a factory reset will erase all data on the device and return it to its default settings. To perform a factory reset on the MC3300 scanner, follow these steps:
- Press and hold the power button and the volume down button simultaneously.
- Keep holding both buttons until the scanner vibrates and the Motorola logo appears.
- Release both buttons.
- Use the volume buttons to navigate to the "Factory Reset" option, and then press the power button to select it.
- Confirm that you want to perform a factory reset by selecting "Yes" using the volume buttons and pressing the power button to confirm.
- Wait for the scanner to reset and restart. This may take a few minutes.
If a factory reset does not resolve the issue, you may need to contact Motorola's customer support for further assistance.
2/24/2023 9:51:25 PM •
Motorola...
Answered
on Feb 24, 2023
4410md default password
Buen d?a tengan todos, se tienen unos equipos Motorola DSR 4410 MD, DSR 4460 y DSR 6100, los cuales cuentan con puerto 10/100 para gestion y configuracion remota, nos pueden facilitar el login y password ya que al ingresar por el explorador el equipo solicita clave de acceso. quedo atento y gracias por su ayuda.
11/8/2021 8:55:47 PM •
Motorola...
Answered
on Nov 08, 2021
One of my two Motorola TLRK T4's generates a static white noise but the other one doesn't.
You didn't say whether the radio still worked ok apart from the noise...
Defective components can produce such noise as can a dry soldered joint - a dry joint is a fairly common fault.
A white type noise is typical of many types of receiver when the squelch is turned down. The squelch circuit is designed to reject signals that are too weak to receive with sufficient strength to be intelligible and in doing so also blocks the background "static". On many CB and VHF type receivers the squelch level is adjustable but tends to be either preset or automatic on basic walkie-talkie type radios. Perhaps the squelch requires adjustment or perhaps the circuit has stopped working.
6/9/2019 8:31:47 PM •
Motorola...
Answered
on Jun 09, 2019
