FixYa.com
IBM Internal ZIP Drive
All Products > IBM > Zip and Other Drives
Problems with IBM Internal ZIP Drive?
Search inside IBM Internal ZIP Drive Knowledgebase
Troubleshooting and Support
Solved Problems for IBM Internal ZIP Drive RSS Feed Post a New Problem
How to read PC (MS-DOS) Zip cartridges on...
How to read PC (MS-DOS) Zip cartridges on a Macintosh?
1 Solution
can't re-synchronize deleted files
When i try to synchronize files onto my device that i have already had on it once and deleted, they dont re-appear and...
1 Solution
Trutech Digital Picture Frame
My frame does not seem to be working with my Memory Stick, which is a Sandisk 512MB...all the frame does is clear for a...
2 Solutions
problem regarding the write protection of...
sir, i am not able to delete files from my pendrive nor am i able to format. every time i try to delete or format,...
4 Solutions
USB Cables
I've lost the cable to my "Smartdisk FireFly" USB storage device. Are most of these cables proprietary to...
1 Solution
circuit diagram of power supply of scxi...
cn i get the circuit diagram of power supply of scxi 1001 from anywhere. i have 2 check the scxi kit that i have....
2 Solutions
hello
when i open my drive it whows open with dilog box . how to solve this problem
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
TypeZIP
Enclosure TypeInternal
Capacity100 MB
Technical Features
Data Transfer Rate1.1 MBps
Storage TypeDisk Drive
Dimensions
Depth.83 in.
Height5.16 in.
Width5.56 in.
Weight.62 lb.
Warranty
Warranty1 Year
IBM Contact Information
Main support number1-800-IBM-4YOU / (1-800-426-4968)
Email supportaskibm@vnet.ibm.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
