20 Most Recent
3Com (3c17462) Questions & Answers
Hoe do you reset a 3Com Superstack3 3870 to
Username: recover
Password: recover
*** Password Recovery Mode ***
The administrative password will be cleared if a hard reset operation is
carried out on the device within 30 seconds.
If a hard reset operation is not carried out during this period, the device
will return to the CLI login prompt.
Stacking Cable / SuperStack3 3870
Found this on 3Com website:
The SuperStack 3 Switch 3870 family (3870-24 and 3870-48) can stack up to 8 units high. Stacks can be formed with any combination of 24-port and 48-port units, with a maximum of 384 (8 x 48) front panel ports supported. When connected together, a stack of units is managed as a single entity. All units in the stack need to run the same release of the operational version code (firmware).
When units are stacked together, they operate in a master-slave relationship. One unit acts as a Master and the other units act as slaves. When looking at a stack of units, the master can be identified by looking at the Stack Master LED on the left side of the switch. The Stack Master LED is green for the Master.
If the unit numbers are out of sync, go to the CLI command that allows users to re-number their units- system / control / renumber. This will re-number the units in the stack. It will take about a minute or two.
The master is the only unit that has a visible command line interface (CLI) when a console cable is connected to it. If you connect the console cable to a slave unit, you will not see the CLI menu, but instead see slave status messages being displayed. The Master unit may not be unit 1.
http://knowledgebase.3com.com/consumer/esupport.asp?id=GUIDbfa9caa4%5F138f%5F4681%5Fbaaf%5F5c99ec5b7ff4&resource=&number=0&isExternal=0&nShowFacts=&nShowCause=&nShowChange=&nShowAddInfo=&activepage=statement.asp&bForceMatch=True&strCurrentSymptom=3C17462&searchtype=normal&searchclass=&bnewsession=false&selecttype=match
I have AVI Video and it only plays sound
Ok it is may be do you to system is old needs up to date , so that the video may not have downloaded completely from the source web portal. The media player present in your handset is outdated.
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers
HI,
I have two 3com
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working.
My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20.
The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables.
Facebook recovery
notify the police dept / person handling the case and let them know about the face book information
