20 Most Recent ASUS G74SX-A1 17.3in Laptop i7 2GHz 12GB 1.5TB Blu-Ray Questions & Answers
tip
Save the Dell battery power
Save the Dell battery powerIt is not that the battery has expired during the flight of important meeting or during long distance. Even though the technology has advanced, the time the notebook PC of the battery lasts on a single charge is limited. It is important to take full advantage of the power that can be used.At any time you might have you already how the power of the notebook PC can be secured. You can always prepare a spare battery, you can carry the code of power, for the prepared might have (optimal battery charging method to be able to charge your notebook PC when the power plug is used, it always Please follow the manufacturer's instructions.)for if these methods did not work, we'll show you how to help prolong the battery life of your computer.Select a power plan that saves power.The power plan, for managing the use of power by the notebook PC, and is a collection of hardware and system settings. The Windows 7 has two default plans.300Balance. When necessary, the brightness of the performance and display the maximum, the computer will save power when idle.Saving power. This is the best choice to be long-lasting battery life. Disadvantages are that performance is slow, is that the screen is dark.The computer manufacturer may other than these plans are provided.Show allTo change the Asus AP21-MK90 batteryYou can also create a custom power saving power plan. For more information, please refer to the "Create a power plan (setting), change, or delete".It will reduce the brightness of the display.The display, you may want to consume more power than other any computer components, such as a hard disk, CPU. In the notebook PC is, to see whether such a device is attached to even your notebook PC that has those dedicated button or dial to change the brightness of the display is equipped, it comes with the computer to examine the documents or, please visit the manufacturer's Web site. Brightness of the display, you can also be adjusted from the Power Options in Control Panel.It will shorten the time to turn off the display in Windows.Even a little time, when you do not use the notebook PC, when certain of the non-operation state continues, you can darken, and the power of the display should be set up Windows so that off, you can save power .Windows is or dim the display, to select the timing to turn off the powerTo remove it or turn off the power to the device you are not using.Many USB devices, power is only connected is consumed. If you are using a USB mouse, the mouse is removed, the use of the touch pad or tablet pen, you can save power. If you are using a USB flash drive, please remove when not in use.Please turn off the PC cards and integrated wireless devices.Power in these devices is consumed. If these are not necessary, please turn off the power.It's laptop battery is never cheap.Even if you always use the AC adapter, since the emergency and is no use when used in battery mode does not make sense, there is software for not as much deterioration as possible battery is something happy.Even so, well it is possible to have Na ~ ThinkPad is.You can replacement purchases a personal computer, you might be happy to buy a personal computer that is attached anti said software when you buy new.Whether laptop for a better power supply that was being? We have been asked many questions that.The following is an excerpt from BIGLOBE of e-mail magazine. Please refer to."Compared to when you buy a laptop, battery less of became fast", "as much as possible the laptop battery want to last longer!" To anyone who wants.In order to preserve as much as possible the life of the G74SX battery, I will introduce a point and tricks you want to be careful!Caution those who have this kind of use!Did you mean, why not or not use while charging the laptop?Many, lithium-ion batteries of the battery being used in laptop battery. This battery, charging becomes violently degradation and followed by a state that is a 100 percent, I would shrink the life of the battery (?) is.300Attention also anyone who "every day, have a charge the laptop before going to bed." Battery has been said that the number of times that can be charged about 500 times. In addition, the battery as long as they continue to charge, tries to keep 100% of the full charge. However, in practice, always because it has happened discharge is in the personal computer, it is finely repeatedly that state because charging, the consumption ? battery charge the battery is 100% ? discharge.Therefore, you can not use while plugged the AC adapter into an electrical outlet in the same sense as the desktop personal computer, and has a charge every day, the life of the Sony battery will become more and more short.Smartphones, also has been used a lithium ion battery and the laptop. This article also ne please refer to!? To extend battery life, the three causes of the daily ed] & battery deterioration to note this!? In the article, the life of the battery, it points a state in which the capacity is reduced by half, which can be charged as compared to when new.And ... in order to prolong the life of the batteryThe first is, that it is not used while charging the laptop.As mentioned above, using a laptop while plugged the AC adapter into an electrical outlet, the life of the rechargeable battery will become more and more short. "Less likely to bring a laptop to the outside, it is often used in a fixed location of the room," anyone who wants to, there is also a hand in that, should remove the battery except when you carry around.The second is, that you do not blindly charge.If you have to charge every day, it is will be increased, but the number of charges by that amount of course. And such as a battery is charged only when the cut 20%, you can reduce the number of charges to be decide my own rules.Third, that the bear in mind as much as possible to 80% charge.If there is an item that can be set the state of charge of the battery of the laptop power settings, it can be set so as not to be in full charge (?).I have to try that "sub-zero beer" to drink at home, "Strong via cooler"For example, in the case of certain laptop DELL, proceeds HP charging battery in the Control Panel ? Power Options ? desktop mode, you can set the use of the from the desktop mode tab, battery.? Whether or not there is a power setting, it is more on the model of the laptopThe battery is a consumable. Please, let as much as possible long-lasting using it well!http://pingcong.269g.net/article/19760799.htmlhttp://blogs.yahoo.co.jp/applelistapple/13000521.html
How can I fix a conection problem from my Asus G74SX laptop via HDMI changes my resolution on my laptop
its because the screen resolouton is different on the tv than the laptop . update your graphics and system drivers.
12/16/2014 1:53:15 AM • ASUS G74SX-A1... • Answered on Dec 16, 2014
ASUS P4S800-MX Error message STOP: 0xc00007b error during Windows XP installaton
Probably corrupt DLL files, maybe due to incorrect decompression or dirty CD.
1/22/2024 7:50:40 PM • ASUS Computers &... • Answered on Jan 22, 2024
My 4-year-old Chromebook laptop is getting slower. Is there a way to improve the performance of the Chromebook?
Run CCleaner
Download CCleaner
Download CCleaner for FREE. Clean your PC of temporary ... Run MalwareBytes Anti-Malware
Malwarebytes: Cyber Security Software and Anti-Malware
Malwarebytes https://www.malwarebytes.com Malwarebytes gives you protection you can trust, alerting you instantly when we see your information has been stolen. Our live agents can even help you restore ... Both have free versions, but I have bought both. Then go to Startup and remove TSRs (terminate and stay resident programs) that have been added by new programs. ..
1/12/2024 11:24:51 PM • ASUS Computers &... • Answered on Jan 12, 2024
2answers
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
11/10/2023 2:08:22 AM • ASUS Computers &... • Answered on Nov 10, 2023
2answers
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
10/17/2023 10:59:01 AM • ASUS Computers &... • Answered on Oct 17, 2023
2answers
Asus Pro B53S No signal out hdmi or display port
Have you looked it up on the ASUS site? https://www.asus.com/support/FAQ/1015526/
10/2/2023 1:59:24 AM • ASUS Computers &... • Answered on Oct 02, 2023
Need wiring connections for asus M4a785-m motherboard.
Visit M4A785-M - Support (asus.com) and download the required manual.
9/19/2023 12:31:26 PM • ASUS Computers &... • Answered on Sep 19, 2023
Asus rog rg8 ii dont power up
6/23/2023 6:50:54 PM • ASUS Computers &... • Answered on Jun 23, 2023
Graphics card no picture on monitor when connected via HDMI or any cable?
The issue you are experiencing with your graphics card and monitor can be caused by various factors. Here are a few troubleshooting steps you can try to identify and resolve the problem: 1. Check power connections: Ensure that the graphics card has the necessary power connections properly connected. Some higher-end graphics cards require additional power connectors, such as 6-pin or 8-pin PCIe power connectors. Make sure they are firmly plugged in. 2. Verify BIOS settings: Access your motherboard's BIOS settings and check if the primary display output is set to the PCIe slot where your graphics card is installed. It should be set to prioritize the discrete graphics card instead of the integrated graphics (if applicable). 3. Update BIOS and drivers: Visit the Gigabyte website and make sure you have the latest BIOS version installed for your motherboard. Additionally, download and install the latest drivers for your graphics card from the XFX or AMD website. Outdated firmware or drivers can cause compatibility issues. 4. Reset BIOS: Try resetting the BIOS to its default settings. Locate the CMOS battery on your motherboard, remove it for a few minutes, then reinsert it. This action resets the BIOS settings to their defaults and may resolve any conflicting configurations. 5. Check for physical damage: Inspect the graphics card for any physical damage, loose connections, or faulty components. Ensure that it is securely inserted into the PCIe slot and that there are no visible signs of damage on the card or its connectors. 6. Test with a different monitor and cable: Connect your graphics card to a different monitor using a different cable (e.g., DisplayPort, DVI) to rule out potential issues with the HDMI cable or the monitor itself. This helps determine if the problem lies with the graphics card or the specific combination of monitor and cable. 7. Check for motherboard compatibility: Verify that your graphics card is compatible with your motherboard. Check the manufacturer's website for compatibility lists or consult the user manual for your motherboard. In some cases, a BIOS update might be necessary to ensure compatibility. 8. Seek professional assistance: If none of the above steps resolve the issue, it's advisable to contact the technical support of your motherboard or graphics card manufacturer. They may have specific troubleshooting steps or recommend further action, such as warranty service or component replacement. Remember to handle your hardware with care and take necessary precautions, such as grounding yourself and disconnecting the power supply, before performing any physical checks or adjustments.
5/29/2023 7:54:59 AM • ASUS Computers &... • Answered on May 29, 2023
I am using an Asus Vivo mini computer approx 5 years old. Since December I often receive error message across top, "Microsoft Edge (not responding)"
Question edited for clarity and toss in a load of CAPS as needed. Microsoft Edge is one of the worst browsers ever invented. It is flashy and looks pretty, but is not user friendly and is glitchy. The most likely issue for that Error Message is your Internet Wifi signal dropping out. You can test this theory two ways. Do you have a smartphone? Download the Free App Speedtest. When you get the Edge Error, whip out your phone and do a Speed Test. If it stalls or only returns a speed of 5 to 10 mbps, that is your issue. Or Download Google Chrome which is FREE and a much more robust browser and easier to use. Keep both Edge and Chrome open, when Edge collapses, try to do things on Chrome. If Chrome works, then the issue is Edge. If Chrome also fails, the issue is your Wifi and Router. A Router reboot should be done about once a month. Google Chrome Download - Download Google Chrome google.comhttps://www.google.com Continue your browsing experience from desktop to phone on Chrome. Download today. Now more simple, secure, and faster than ever - with help from Google built-in. Google Address Bar. One browser, all devices. Type less with autofill. Chrome support.
Download Now Get a new and fast web browser. Download Chrome and start browsing.
5/1/2023 7:50:39 PM • ASUS Computers &... • Answered on May 01, 2023
I inherited an Asus UX50V with Linux installed and would like to restore it to Windows 7.
The restore disc should have Product ID Key and that is all you need. Any password is entered after the install IF you want it password protected.
3/8/2023 5:01:53 PM • ASUS Computers &... • Answered on Mar 08, 2023
Euro symbol on keyboard for ASUS
This is the Keyboard Shortcut 1. Using the Alt keyboard shortcut to add the euro symbol:
  1. Place the cursor where you want the euro sign to appear.
  2. On the numeric keyboard, hold down Alt while pressing 0128.
  3. Use the numeric keypad's NumLock button if the sequence doesn't work.
How to Type the Euro Symbol? - DataFlair
More here https://www.google.com/search?q=Euro+symbol+keyboard+shortcut ..
3/7/2023 7:24:55 PM • ASUS Computers &... • Answered on Mar 07, 2023
My asus laptop turns on but there is just black, the power indicator says its on.
If you are experiencing a black screen issue on your laptop, the first thing you should do is to make sure your laptop is powered up correctly. Check the cable from the power adapter to the laptop, and make sure it is firmly plugged in. If it is, then you should try resetting the power supply on your laptop. To do this, unplug the power adapter from the laptop, press and hold the power button for 30 seconds, and then plug the power adapter back in. If the laptop still does not display any images, you should try reseating the RAM chips. First, try to turn off and unplug your laptop, and then remove the battery. After that, open up the RAM memory slot, and use a screwdriver to press down on the RAM chip securely. Then, replace the RAM chips and the battery before turning on your laptop. If these troubleshooting steps do not work, then it is likely that your laptop may have a hardware issue, and you should take it to a repair shop.
2/24/2023 7:56:23 PM • ASUS Computers &... • Answered on Feb 24, 2023
How can I get into my Asus T100?
AS MAKER YET>? ASUS.COM FOR HELP I SEARCHED FOR YOU THERE AND GOT THIS. https://www.asus.com/US/support/FAQ/1046347
2/23/2023 3:30:42 PM • ASUS Computers &... • Answered on Feb 23, 2023
MY ASUS T100 keyboard is not working.
Double check that the tablet is sitting properly in the keyboard Is this the model where you can charge via the keyboard - plug the charger into the keyboard? Reply with more info
2/22/2023 5:48:18 PM • ASUS Computers &... • Answered on Feb 22, 2023
AMD Ryzen 5 5600G causes BSOD after instaling graphics driver
t is possible that the issue is related to a driver conflict or compatibility issue between the graphics driver and the operating system. Here are some troubleshooting steps you can try:
  1. Update the graphics driver: Download the latest version of the graphics driver from the AMD website and install it. This may resolve any compatibility issues that were present in the previous driver version.
  2. Run Windows Update: Check for any available updates for your operating system and install them. This can resolve any compatibility issues with the graphics driver and other system components.
  3. Check the device manager: Open the device manager and check if there are any issues with the graphics card or other devices. You may need to update or reinstall the driver for the device.
  4. Check the system memory: Use a memory diagnostic tool to check if the system memory is working properly. Faulty memory can cause BSOD errors.
  5. Check the power supply: Insufficient power supply can cause system instability and BSOD errors. Check if the power supply is adequate for the system configuration.
  6. Disable or remove any third-party antivirus or firewall software: In some cases, these programs can interfere with the graphics driver installation or cause conflicts with system components.
If none of these steps resolve the issue, it may be a hardware problem with the graphics card or the motherboard
2/16/2023 2:39:33 AM • ASUS Computers &... • Answered on Feb 16, 2023
Bad bios checksum on motherboard
Sounds like the wrong bios file has been installed. Try to reload the original, at least it worked.
2/14/2023 7:34:00 AM • ASUS Computers &... • Answered on Feb 14, 2023
I used jumper bios reset
Hi.
The most probable reason you are getting the bad checksum error is you have to set the date and time because you have cleared the CMOS and reset the BIOS.
You should also get a message that says press F1 to load defaults or press a certain key to access setup. Access setup (BIOS) and set the date and time. That should take care of the bad checksum error.
Another good idea is make sure the motherboard battery is not dead either.
Regards.
2/13/2023 8:24:18 AM • ASUS Computers &... • Answered on Feb 13, 2023
ASUS G74SX-A1 17.3in Laptop i7 2GHz 12GB 1.5TB Blu-Ray Logo
2 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
fix conection problem from asus g74sx
  • Computers & Internet
