20 Most Recent
Acer Emachines E525 E625 E627 E630 E725 Palmrest Questions & Answers
Why did my touchpad mouse disable?
Either the hardware itself has failed or perhaps the driver has become corrupted. Go into the device manager, locate the trackpad driver and delete it. Exit the device manager and reboot. The device driver should be reloaded (trackpad seen as a new device), you may need your Windows CD but then again sometimes you don't.
Touchpad scroll
JUST TRY SOME DIFFERENT MOUSE, IF IT IS WORK YOU NEED CHANGE TOUCHPAD IF NOT SOMETHING WRONG WITH MOTHERBOARD
Dont power
If the m/b is truly broken (not some other component) you will have replace the motherboard. You may be able to salvage the RAM and the processorcooler from the motherboard. You may be able to buy a working identical replacement either from new or second-hand (ebay).
You might even be able to diagnose the fualt and repair it/have it repaired by an expert the motherboard if you are very lucky, but this usually not worthwhile.
Before taking these steps, ensure that the problem IS that he motherboard is actually broken.
20.April.2014
Cant see my gmail
Point your web browser at
http://www.gmail.com
If another account comes up, sign out of it by clicking the avatar in the upper-right then clicking "Sign out."
If you can't sign into your account, click the "Can't access your account?" link on the sign-in page.
How to factory reset my E625
if you still have the original partition of the hdd , shut down the pc and after 15 sec. turnit on and press f11 key to enter full recovery mode.
My eMachines E627 series... Does not open up to
Go to Acer's website and look up their beep codes to see what it means. Sometimes it's a problem with a RAM stick not being seated properly, a corrupted sector on the hard drive, or something stupid like a dusty power supply.
Black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.- Removing the graphics driver in safe mode might work for you. Just remove it via Device manager and update them- Check for registry issuesIf this didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
