20 Most Recent
Intel D845GVSRL 533MHz FSB 845GV Chipset DDR333 Socket 478 microATX Motherboard with Vid... (MB47IN5GVSRL) Questions & Answers
How can download lan driver
The first move you can take when having a trouble with Windows drivers is tocheck Windows update by clicking on Start->Programs-> Windows Update andrefreshing the list of driver. Windows update searches a compatible driver onInternet. If it fails to locate a suitable driver, we suggest you to contactthe hardware vendor or visit the website for latest drivers.
No display
If you have intagrated graphics it might be problematic or possibly bad. Try a different monitor. If that does not work then you could try an add-in ..either PCIe or PCI graphics card to see if that works. I no luck there then the motherboard is most likely DOA.
Where do i download intel 845 lan driver
1)Go to downloadcenter.intel.com
2)Your product is discontinued and so you check mark the discontinued product which will be viewed at right corner under find downloads by product name.
3)Select desktop boards under select a product family.
4)Select Intel 845 chipset family boards under select a product line
5)Select the mother board model under select a product name
6)Select your operating system from the list
7)select drivers from the download type
8)Download the lan driver which is available
Hope this information is useful to you.Feel free to post your comments.
THANKS FOR USING FIXYA
BEST WISHES
My computer is booting and
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
When I install vista os the blue screen appear in
The operating system is not compatible with the physical configuration of you computer...
this is the reason...
install XP and install a tranformation pack for vista to have a glossy look of vista in XP...
Hi sir
hi im josh in cebu phils.may i help you? Friend you can download your intel D845GVSRL sound driver to this site below:
http://driverscollection.com
http://www.motherboard.cz/mb/intel
thats all friend good luck hope i helped you.
Hj hlep me looking for
Here is the link for the download , just go to it then select O/S then on then go and on the new screen select driver and which one then download and install.
Here is the Link:
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=757&lang=eng
I hope this helps
Installing new powersupply
what is your problem? the wires go up and go on 2 wires sticking up they should have something below them that match, you may not need all of them hooked up. the power you need, tri hooking them up and turn the computer off and on each time till you find out where the go.
How long does the Intel i7-930 processor expected to last?
The best way to prolong life of a computer is to blow out dust from the case and cooling fins and power supply regularly, at least every year. That prevents overheating - a primary cause of component failure. Do not overclock.
Do periodic full disk backups and intermediate new file ones. Leapfrog between two external disks. They are cheap. Protect them from fire.
Laptops - same story,, do not block cooling holes by putting on a blanket while lounging. And turn off machine before blowing out dust. Do not use full PSI compressor air! maybe 20 PSI...
Intel D865GVHZ Motherboard won't boot into anything but will turn on
If your Intel D865GVHZ motherboard is not booting and you've tried replacing the CMOS battery, resetting it, reseating RAM, and changing the PSU, it may indicate a more serious hardware issue. You should consider checking the following:
1. Check the monitor: Ensure that the monitor is functioning correctly by trying it with another computer.
2. Check the connections: Verify that all cables, including the power and video cables, are securely connected.
3. Inspect for hardware failures: Check for any visible signs of hardware damage or loose components on the motherboard.
4. Test with minimal hardware: Disconnect all unnecessary peripherals (e.g., external drives, graphics cards) and leave only the essentials connected (CPU, RAM, power, and monitor) to rule out any conflicts or faulty hardware.
5. Try a different RAM: If possible, test with different RAM modules to rule out faulty memory.
6. Listen for beep codes: If your motherboard has a speaker, listen for any beep codes during startup, as they can provide clues about the issue.
7. Inspect the CPU: Check the CPU for any damage or bent pins, and ensure it's seated correctly.
If none of these steps resolve the issue, it's possible that your motherboard or other critical components may have failed, and you may need to consider a replacement or professional diagnostics to pinpoint the exact problem.
Smart response technology
Intel Smart Response Technology (SRT) is used for SSD caching to improve system performance. To use it successfully, here are some steps to consider:
1. SSD Compatibility: Ensure that your SSD is compatible with SRT. It should be a SATA SSD.
2. BIOS Settings: In the BIOS, set the SATA mode to RAID (not AHCI or IDE) before configuring SRT. Make sure your motherboard supports SRT as well.
3. Driver Installation: Before enabling SRT, install the latest RAID drivers provided by your motherboard manufacturer.
4. Backup: Backup your important data because enabling SRT involves data migration.
5. Enable SRT: In the BIOS, set the SRT mode to "Enhanced" or "Maximum" depending on your preference.
6. Initialize SSD: Initialize and format the SSD through Windows Disk Management.
7. Install Intel RST: Download and install the latest Intel Rapid Storage Technology (RST) driver and software for your chipset.
8. Enable SRT in RST: Open the Intel RST software and enable SRT. You should see an option to accelerate your HDD with your SSD.
9. Reboot: After configuring SRT, reboot your system.
10. Verify: Check if SRT is working by opening the Intel RST software. It should show your SSD as a cache for your HDD.
If you're encountering crashes or issues, it's essential to ensure compatibility and follow these steps carefully. If the problem persists, consider seeking assistance from your motherboard manufacturer's support or Intel's support, as it could be related to specific hardware or software conflicts.
How can I troubleshoot a slow computer performance?
The end part of your question makes it sound like an advert.Download and run the Free version of CCleaner. Remove TSR (terminate and stay resident) programs on start up. These are the programs that run in the background.Download CCleaner 6 For Free - Make Your PC Faster & Saferccleaner.comhttps://www.ccleaner.comClean Temporary Files, Optimize & Speed Up Your Computer. Download Now. The No. 1 Tool for Cleaning Your PC. Download CCleaner now. Browse Solutions. View Products. Multiple Payment Options...
