20 Most Recent Adapters.com Fiber Optics Cable SC/SC Duplex PVC Multimode , 25 ft (FO1MD7725) Questions & Answers
If it is loose tube cable, than you can do it in two ways. First using SC SM pigtails, which should be spliced on each fiber (don't forget that you need to protect the splice itself and protect bare fibers puttung them in same cassete or tray or ....) or the other way using "break out system" which will give your bare fibers more protection but the SC connectors can be mounted directly on the fiber in this system. Cheaper and preferable way is the first one.
If it is tight buffered cable there is also two ways of termination. First, directly mount SC connector on a fiber (no need for break out system) or splice SC SM pigtails. Cheaper and preferable way is the first one.
Adapters.com... | Answered on Sep 20, 2009
If you are trying to use a USB plug as a NIC card, you need a converter, not an adapter.
Amazon com AmazonBasics USB 3 0 to 10 100 1000 Gigabit Ethernet Adapter...
Adapters.com... | Answered on Sep 28, 2017
192.168.1.1 its open but username password is not wrking, why. plz send solution
Adapters.com... | Answered on Jul 03, 2015
dear babloofee,
Unlock Code: 60457619
if anybody want unlock code, please mail your IMEI and model number to unlockidea@gmail.com
http://unlockideanetsetter.blogspot.com
Adapters.com... | Answered on Mar 04, 2012
You can know Your internet speed in the site http://www.ip-details.com/
Adapters.com... | Answered on Dec 22, 2010
Most Likely has a DEAD CELL in it and Requires Replacment
Adapters.com... | Answered on May 10, 2010
i can play, but i can't connect with my friends. It says cant find Host. what is wrong?
Adapters.com... | Answered on Mar 23, 2010
I presume you need Internet access in this house using a wireless network.
The best place to locate the wireless router is in a spot centrally located where the radio signals can reach the rooms where the computers are located. The DSL or cable modem/connection would also need to be in this area so it can connect to the wireless router.
If the wireless router is in a multi-storey house and the floor slab and walls are concrete and/or brick, then the radio signals will be impeded and the signal strength to some rooms will be weak.
In such circumstances, it maybe better to install network cables from these rooms to the wireless router, or install wireless access point repeaters to increase wireless coverage.
If you are not sure how to setup and install this network, then I suggest you get help from a computer savy friend or from your computer friendly shop.
Adapters.com... | Answered on Nov 04, 2009
The standard 10/100 PCI ethernet card will be compatible with all Personal computers.As for brand realtek is my choice.
Adapters.com... | Answered on Oct 24, 2009
i connect to the wireless adapter its very easy go to the wireless adapter & refresh to the network list if your notification area will have a wire less network when the wireess adapter search any connection then you see a option connect then click connect
Adapters.com... | Answered on Sep 19, 2009
Click on "My Profile" in top right corner.
Then click on "Edit Profile" in top left corner.
Scroll down the page to the "Upload your Profile Picture" section.
Browse for your favorite picture.
Click on "Save Changes" blue button at the bottom of the page.
Adapters.com... | Answered on Aug 30, 2009
the battery sounds like it has bad battery memory and needs to be replaced. Before you replace it look for software to give you the battery's status (how much charge it holds out of how much it should hold by design. for exaple i am using ubuntu linux and my battery reads
Capacity: 29% (Poor)
Current charge: 14.3 Wh
Last full charge: 14.3 Wh
Design charge: 48.8 Wh
Charge rate: 10.0 W
now that is my bad battery for staying at home and leaving it plugged in all the time (that kills the battery) i have another battery that reads
Capacity: 97% (Good)
Current charge: 38.8 Wh
Last full charge: 47.5 Wh
Charge rate: 5.5 W
it is my battery for travel. the difference between the two is that the battery that reads Capacity: 29% (Poor) only lasts about 40 minutes but the battery that reads Capacity: 97% (Good) lasts 3 hours. you probably have a low Capacity.
Adapters.com... | Answered on Aug 18, 2009
(Post ur Operating System along with the problem and the Brand name of ur laptop)
Chk whether the wireless is turned On or not.
Certain laptops requires manual command from the user to turn on the wireless.
If possible try to remove the wireless from ur laptop and try to re-install it and re-install the drivers also.
Adapters.com... | Answered on Jul 01, 2009
Depending on the phone you should be able to search the web and download the software drivers for your phone.
Adapters.com... | Answered on Jun 30, 2009
Adapters.com Fiber Optics Cable SC/SC Duplex PVC Multimode , 25 ft (FO1MD7725) Logo
1 questions posted
Top Adapters.com Computers & Internet Experts
Jeff richtman
Jeff richtman
Joaquim Martins
Are you an Adapters.com Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Adapters.com Computers & Internet
Most Popular Question
fiber optics termination
  • Computers & Internet
