This should be the motor you need. Your oven model is not specifically listed, however the same part is used for many Siltal manufactured ovens, I believe yours is one of them.
Tecnik is effectively just a 'badge' meaning there are numerous other 'badged' appliances which share many common parts.
I would advise you verify this with UKWhitegoods before ordering just to be sure. You can email them on [email protected] or alternatively, complete the online help form, which can be found here:
I have used this supplier many times and recommend them. They answer enquiries quickly, always give the correct information and delivery times are excellent.
Hope this helps. Please post back if you need further assistance.
First disconnect power for at least30 seconds. Re-apply power and observe for at least one minute. If codere-appears, you need to replace control board (also called ERC or clock).
For draining problem: Verify drainpump operation - verify that the pressure switch hose is in good condition andproperly connected to tub and pressure switch. Please check these -
1. Verify there is not a siphon problem. 2. Unplug washer or disconnect power. 3. Verify wire harness connections to inlet valves, pressure switch, drainpump, flow meter, and Central Control Unit (CCU). 4. Check all hoses for possible leaks. 5. Plug in washer or reconnect power. 6. Verify pressure switch operation. 7. Verify flow meter operation by blowing air through the part and measuringthe resistance. 8. Verify CCU operation by running a Diagnostic test or any cycle.
If you findanything, replace failed component.
Hope this willhelp you. Good Luck.
