Intel Server Board SAI2 Motherboard
Problems with Intel Server Board SAI2 Motherboard?
Keep your PC up-to-date. Get a Free Scan for Intel's latest driver updates.
Troubleshooting and Support
Solved Problems for Intel Server Board SAI2 Motherboard RSS Feed Post a New Problem
kzm 6120
my problem goes this ways... i uprgraded my o s from win98 to windows xp pro.. at first, it worked will, but after i...
2 Solutions
memory/swapping problem
The only issue that I've had that remotely resembles that involes CPU usage, not memory. Assuming your statistics are...
1 Solution
Hi there
Thanks for your help on the Canon MP160 printer. Problems is solved. I am sitting with a new driver problem. See, I am a...
1 Solution
Compaq C502US Laptop Won't Boot LEDs flash
I have a Compaq Presario C502US laptop that will not boot. The minute I plug it into the a/c adapter the red charge led...
1 Solution
sigmatel driver
how or where can i fnd sigmatel high definition audio codec driver for my dell latitude d420 laptop? please help me. i...
1 Solution
Whining noise from pc tower
The pc has got this annoying high pitched sound. I've checked the HDD by replacing it with another one. I've...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Form FactorATX
CompatibilityPC
ChipsetServerWorks ServerSet III LE (3.0 LE)
Compatible ProcessorsIntel Pentium III
Front Side Bus Speed133 MHz
Technical Features
Expansion SlotsPCI x 4 · PCI-X 64 Bit (66/33 MHz) x 2
Integrated Input/Output PortsSerial Port x 2 · USB 1.1 x 2 · PS/2 Mouse x 1 · PS/2 Keyboard x 1 · Parallel Port (ECP/EPP/SPP) x 1 · RJ45 Lan Port x 1 · Floppy Port x 1
Storage Controller Type(s)DMA/ATA-100 (Ultra) x 1
Processor
Max supported CPUs qty2
Socket TypeSocket 370
Memory
Max Supported RAM4 GB
Memory TypeSDRAM
Supported RAM Speeds133 MHz
Number of Memory Slots4 x 168 Pin SDRAM DIMMs
Audio / Video
Installed Video Memory8 MB
Video InterfacePCI
Integrated Graphic CardIntegrated Graphic Card
Video Out Ports15 Pin D-Sub VGA port x 1
On Board Graphic ProcessorATI Rage XL
Communication
Networking TypeNetwork Adapter
Other Features
Chassis Type1
Fans6 x 3-pin fan headers
Dimensions
Depth10.01 in.
Width12.02 in.
Warranty
Warranty3 Years
Intel Contact Information
Main support number800-404-2284 / 916-377-7000
Sponsored Links
Loading problems.
Top Experts
Ask Me
ravs Wiz
2 solutions
Ask Me
bochard_2 Wiz
1 solutions
Ask Me
map9966 Guru
58 solutions
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
