20 Most Recent Superstar 3900 Questions & Answers
Tring to wire up sadelta hand mic the mb-4 to the superstar 3900 but dont know the wiring there are 5 wires the couler of the wires are screen white red green andbrown can you help
I would like to state there are two ways to do this, one way is too open the radio cover up and look at the back of the jack where the mic goes and the color of the wires should be the same, or you can do it the second way which is a little longer and patience to do take the wires of the mic and touch one at a time to a prong one should get you sound when its right the other should transmit when you push the handle to talk on the mic
7/3/2014 3:02:56 AM • Superstar 3900 • Answered on Jul 03, 2014
Superstar 3900 meter not working
Need more info, is the wires soldered on, has one broken, on board do you get a reading an not on meter? Could be meter or poor solder or broken wires. Because you dont get readings at all, tells me its more likely the meter or connections
3/26/2014 5:28:19 AM • Superstar 3900 • Answered on Mar 26, 2014
Superstar 3900 el led rx/tx cambia a naranja en ves de rojo
There can be several things for that. 1 a bad microphone.2. bad switching diode. or 3 bad rx/tx transistor.. if its staying orange. the #2 is probably the issues.can you provide more detail, as will it RX.. at all.? will it work in PA mode if theres one? etc
5/7/2013 7:43:14 PM • Superstar 3900 • Answered on May 07, 2013
Problem with Superstar 3900 CB Radio
did you found the problem,mine has the sam problems...reception not very loud on ssb,am fm very good...
7/4/2021 5:59:04 PM • Superstar Radio... • Answered on Jul 04, 2021
Superstar dm 507 microphone wiring diagram
Request the wiring diagram from Superstar.
2/11/2021 5:29:10 PM • Superstar Radio... • Answered on Feb 11, 2021
Proper adjusting the knobs on a superstar cb radio
Which model do you have ?
12/2/2016 1:36:24 PM • Superstar Radio... • Answered on Dec 02, 2016
2answers
Where is modulation chip on superstar 4900b
open it u will find it ' it will be very small and it will be hard to do something with it
3/20/2016 3:12:00 PM • Superstar Radio... • Answered on Mar 20, 2016
Superstar 121. What is the keying diode number (board number)?
You can use Two 1n914 or 4148 styles in series.. to replace it.. shouldn't cost more then 16 cents for two..
2/2/2016 3:08:18 PM • Superstar Radio... • Answered on Feb 02, 2016
Wire a superstar 452 dm to corba 29 ltd classic nite watch
Cbtricks.com.
3/10/2015 1:21:30 AM • Superstar Radio... • Answered on Mar 10, 2015
0answers
Superstar 3900 Logo
Popular Tags
8 questions posted
Top Superstar Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Superstar Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Superstar Radio Communications
Most Popular Question
tring wire up sadelta hand mic mb 4
  • Radio Communications
