20 Most Recent Uniden D1685 3 Cordless Phone Answering System With Speakerphone And Handsets T Questions & Answers
Find the MENU button on the handset, then select Handset Setup. Scroll through the menu to locate the option you need to change.
Uniden D1685 3... | Answered on Sep 13, 2014
The Uniden XDECT 8315 does not have an answering machine. It will check your voice mail. Setting that greeting depends on your telephone service provider. Check your provider's voice mail FAQ.
To have your XDECT 8315 get your voive mail messages, press Message and then select Voice Mail. Then follow the prompts to enter your voice mail access number. Alternatively, you can press Menu > Global Menu Settings > Edit Voice Mail. See pages 17 and 32 of the manual. (See the link below.)
The manual for the XDECT 8315 is available on the product page: https://uniden.com.au/product/xdect-8315-1/ . The current link to the manual is https://uniden.com.au/wp-content/uploads/2017/06/XDECT_83151_OM.pdf .
If you do not have voice mail from your telephone company, you can add a stand-alone answering machine. Just make sure to connect the answering machine to the telephone jack. Then connect the answering machine RJ-11 out to the telephone's RJ-11 jack on the base.
I hope this helps.
Uniden Lands... | Answered on Jul 04, 2019
Usually you can press block calls again it will give you your list of numbers and you can usually unblock from there. If nothing helps call Uniden customer service and they will help you.
Uniden Lands... | Answered on Jul 01, 2019
If you need to change the greeting then you should use custom greeting to suit your needs. Go to Menu and then settings for answering system go to greetings and it should give you instruction.
what do you mean by "announce"?
if it is the red flashing light say so as there is a fix for that problem
Uniden Lands... | Answered on Jun 21, 2019
I don't think you can transfer to external. You can make a 3 way call, but then you would have to stay on the line to keep that line open.
Uniden Lands... | Answered on Jun 19, 2019
Unfortunately, you can't transfer from the old to the new. There is no data transfer port (usb) and you will have to manually enter your phone numbers into the new phone.
The problem sounds like a wiring fault to me. Landlines ring when the POTS (plain old telephone system) provides power on the receive wire. See https://www.lanshack.com/wire_phone_jack.aspx for the RJ-11 wiring diagram.
Try a different phone at the jack and a different telephone cord. If it rings constantly, that tells you the problem is with the wiring in the building or outside. You need to find where additional electricity is coming into the telephone wiring. Check the jack first. Most jacks either have screw terminals or keystones. Use the wiring diagram above to make sure that the wires are connected to the correct point. If you have the screw type of terminal, you need to strip the insulation from the conductors before securing the wires. For the keystones, leave the insulation intact. Then use a punch-down tool (available at most hardware stores in the electrical section) to push the wire into the correct slot in the keystone.
There must be a place where the insulation is damaged and touching another wire or water is in contact with bare metal and a current is flowing across the water. If only the Uniden phone rings constantly even with the new RJ-11 cable, replace the phone.
I hope this helps.
Uniden Lands... | Answered on Jun 11, 2019
Contact Uniden directly to inquire.
Uniden Lands... | Answered on Jun 06, 2019
Your Uniden machine defaulted to the standard message that invites callers to call back later. You will have to re-record your message.
Uniden Lands... | Answered on May 31, 2019
Uniden D1685 3 Cordless Phone Answering System With Speakerphone And Handsets T Logo
1 questions posted
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Uniden Lands Phones
  • Uniden Lands Phones
Most Popular Question
get phone ring
  • Lands Phones
