20 Most Recent Pignose Hog 30 Amp Questions & Answers
Check your Ariel connections for corrosion (clean them all up)
Have you relocated the unit?
Have you placed/relocated any other electrical devises near it recently??
Audio Players &... | Answered 2 hours ago
Hello Dilum, make a test to control the sound level of the speakers connected to your harman kardon, you must press for more than two seconds the test key that is on the front panel, in the set of keys at the bottom
With the Test, you will be able to check the volume of each speaker individually, this is explained in the user manual on page 4 Item 9
If with the test, the level is fine, then you would have some problem in the recording or the program you are listening to
I hope I can solve the problem
Greetings Franco Dosil
Hola Dilum, haga una prueba para controlar el nivel se sonido de los parlantes conectados a su Harman Kardon, debe presionar por mas de dos segundos la tecla test que se encuentra en el panel frontal, en el conjunto de llaves en la parte inferior
Con el Test, va a poder chequear el volumen de cada parlante en forma individual, esto esta explicado en el manual de usuario en la pagina 4 Item 9
Si con el test, el nivel esta bien, entonces tendria algun problema en la grabacion o el programa que este escuchando
Espero pueda resolver el problema
Saludos Franco Dosil
https://data2.manualslib.com/pdf/7/658/65714-harmankardon/avr20ii.pdf?3e1777e124b0c9a1878f4d39601e577d&take=binary
Audio Players &... | Answered 6 hours ago
An internal fuse may have opened.
Audio Players &... | Answered 9 hours ago
please give more info of your problem. on what source are you not having sound? in all sources like your tuner, auxilary, tape CD etc...?
Audio Players &... | Answered 10 hours ago
Pignose Hog 30 Amp Logo
8 questions posted
Top Pignose Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Pignose Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pignose Audio Players & Recorders
Most Popular Question
just pignose 7 100 stolen am curious as
  • Audio Players & Recorders
