20 Most Recent Intel Pentium 4 630, 3.0 GHz (BX80547PG3000FT) Boxed Processor Questions & Answers
Hello Prask, Cooling the Intel's LGA775 CPU presents quite a challenge due to it's high operating temperatures, and while the ideal solution would be to use water, not all of us are ready to make the jump. The best solution I found for an easy replacement of the stock cooler is nMEDIAPC ICECONE Pure Copper CPU Cooler. It is an easier install than Thermaltake, and is just as quiet. You can find it here for the best price: http://www.directron.com/icecone.html Let us know if you need any additional assistance. Best regards, nightdiver
Intel Pentium 4... | Answered on Aug 18, 2006
you find out its CHIPSET then you look on the Intel ARK for cpu compatible with that chipset you do that by searching for your current cpu. You can also look at the boards AA number see link. this will tell you the mainboard number, ie the D33025 is NOT the board number but it does suggest the chipset is s series G33. In most cases you cannot simply fit the most powerful cpu listed because designers and builders of boards can RESTRICT a board by the MEMORY speeds allowed and the overall WATTAGE of the cpu. Also your BIOS needs to be NEW enough(ie a date after the release date for that specific cpu. So to sum up your cpu must match your memory dimms speed and the wattage must be kept to the values used for designing the board and the BIOS still needs the cpu number in its list to be able to detct it and configure it correctly it is NOT the case that if it FITS the socket then its ok to try it, it is NOT ok to try it. https://www.intel.co.uk/content/www/uk/en/support/articles/000005624/boards-and-kits.html https://ark.intel.com/content/www/us/en/ark/products/31914/intel-82g33-graphics-and-memory-controller.html
Intel Computers... | Answered on May 10, 2019
Try 0123456789 or 1234567890
Intel Computers... | Answered on Mar 16, 2019
aiden check out the computer dealers sites.
Intel Computers... | Answered on Mar 08, 2019
is it windows lock or hdd lock?
Intel Computers... | Answered on Feb 28, 2019
i want eton webcam driver pls to install in my pc and to used my webcam
Intel Computers... | Answered on Feb 05, 2019
This page should have the driver required for your laptop.
HP E6550 Drivers Download for Windows 7 8 XP Vista
Intel Computers... | Answered on Jan 21, 2019
The usual method of resetting any BIOS is to remove the backup CMOS battery (usually a Lithium coin cell) and then short the terminals for a while (e.g. a minute) with a wire. Then, when you restore the CMOS battery to the BIOS, it sees the settings make no sense and then sets them to default. I warn you that I don't know what an Artx Ultraviolet is, as it doesn't seem to return anything on Google. It's very hard to reset the memory in some modern machines, and more sophisticated motherboards have a reset button to restore default settings. That's all I can suggest without more information.
Intel Computers... | Answered on Jan 16, 2019
Memory Card or USB Drive Recovery Software
Intel Computers... | Answered on Jan 14, 2019
Best setting are the factory defaults in bios, because all hardware
and the o\s have been rigorusly tested,backup before trying new settings.check the intel cpu wether it monitors the load on its processor. most typically overclock at 40% load if you are into
gaming there are to many parameters. depending on your software apps like autocad,then more ram for virtual drive to place work in may help, 8 more
Intel Computers... | Answered on Jan 02, 2019
best to remove all ram and any hardware changes, replace original ram,also delete new opane drivers speakers and all peripherals. Also remove battery tap power button for 5 seconds.
reboot to bios and enter, select setup defaults. now you should continue to original splash screen.this may seem odd, but I have seen a mouse dongle left in and caused a trouble during troubleshooting. this is why as an I.T.TECH, I recommend removing everything, such as speakers,headphones,ext hdd
Otherwise check utube search .for intel optane
i need a samsung mono laser printer SCX-3201G DRIVER DOWNLOWD MY PC
Intel Computers... | Answered on Dec 28, 2018
you can either get a movie downlaoder to help you with this or you can findmovie on free movie sites.
here is the best for you: http://free-download-films.com/
Intel Computers... | Answered on Dec 24, 2018
Intel Pentium 4 630, 3.0 GHz (BX80547PG3000FT) Boxed Processor Logo
Popular Tags
1 questions posted
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
intel p4 3 0ghz 800fsb fan makes more
  • Computers & Internet
