20 Most Recent
Dynex "- 32"" Class / 720p / 60Hz / LCD HDTV DX-32L220A12" Questions & Answers
Have dynex 32''. How do I delete favorites.
When doing setup on some TV's you have to designate if you are using broadcast, cable or digital etc. Be sure that your 'source' selection is correct. Sounds like the #3 and #60 may be the only two signals your TV is picking up. Hope this helps
My screen will not turn on even tho there is power?
Just repaired this TV today. You will need to purchase the inverter board. The TV will power up....you will see "PLEASES WAIT", and disappear, you have a black screen. When you remove the back cover, look to your left. You will see a long vertical board. That is the board you will replace. Seek shop jimmy, enter model number of your TV. You will see an inverter board for $24.95 plus $9.50 shipping. Thanks for asking me, Matt of Martins TV Repair.
We cannot get the sound
I think this is the model, or close to it.
http://downloadcenter.samsung.com/content/UM/201009/20100906145211281/[UC5000-ZA]BN68-02625A-03Eng-0903.pdf
Page 11 talks about audio out.
The actual model of the Dynex would be useful.
Maybe you could get it to come from the actual audio source, like the Cable Box, which has really good audio options while TV's usually don't and add nothing to the sound by being in the loop.
Tried to use mic, only picking up computer sounds.
Ensure that you have selected the Microphone or the Line-in as your recording input. It sounds like you have set STEREO MIX as the recording input. Double click your speaker, select from the drop down "Properties" then Adjust volume for (RECORDING) select that and ensure that your appropriate recording device is selected. (XP)
