Troubleshooting & Support
Hot Topics:
- unlock scanner
- paper feed
- paper jam
- cartridge short
- carrier stall
- 000 error...
- paper
- driver
- vista driver
- slam
- disassemble
- power cord
- drivers...
- x83
- repair
- manual
- carrier
- error a04
- driver download
- channel opened
- clean glass
- feeding paper
- software
- a06 error
- printing color
- install
- drivers
- mac driver
- remove ink...
- paper won feed
- View All »
Problems & Solutions
I am trying to install my printer Lenmark X83 on a
If its a new computer, are you using windows 7? This printer is NOT vista or 7 compatable Your support page says this printer is NOT...
error 0502
Try cleaning the steel rod the carriage slides on, this normally sorts carriage stall errors
roller bars don't seem to be feeding the paper
I found a split 50 tooth gear on the drive roller shaft, and instead of turning the roller shaft, it was slipping, due to the split plastic...
paper jam
Hello there You may not see a paper jam. This may work for you, it has worked for many here I given this advice so gave it a try it could...
printer will not print. drivers installed and
Can the printer do any of the self tests successfully? If it can, then you need to look at the communications linkage (cable) between the...
need power supply cord
Hello, I found one online at 3 different vendors: http://www.unitedsale.com/product_info.php?products_id=17983...
My dealer said my color print cartridge was 3/4
Read on and see if any applies to you. Check that you removed the protective tape. some cartridges have two of these pieces of tape one over...
lexmark x83 does not pull paper through; what do I
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic...
How do I remove the cover of my lexmark X83?
there is a cover there at the back of your printer, pull it down then remove the paper hang on their, then after you remove , check if there...
Paper jam message, but actually no paper jam
Turn off the printer. Remove any paper trays. Inspect them for wrinkled or damaged paper. Also open the back cover of the printer if this...
lexmark x83 error message
there is no communication between my printer and the software.i can scan,but i can not print.
usb cable
The USB connection is just above the power connector and to the upper left of the red scanner lock lever.
Paper will not feed
knwrght is correct in his answer. If you look inside where you would when you change a cartridge, look to the far left side where you can...
need cord
You can visit your local hardware store. Bring with you your old cord. You can also go to the store where you have bought your printer. You...
lexmarkx3470- will print,won't scan
I have to ask. Did you install it via a disk that came with the printer? If so , did the disk specify that it was for the VISA version of...
Unsolved Problems
no power
Is there a fuse that is accessible? If so, how is it accessed? The printer was plugged in and properly connected to...
my printer will not print
my printer will not print from my computer i have a HPvs15c computer and a lexmark x83 printer
When I give the print command, it sounds like the
When I give the print command, it sounds like the printer cartridges have sprung to the opposite side of the printer and...
jlexmark x83 printer will grab
jlexmark x83 printer will grab paper and feed in 1/2 way but no farther, I can see bottom roller spinning like crazy and...
Paper starts in when I push 'copy', but
Paper starts in when I push 'copy', but will not continue to be printed. Error message simply says 'paper...
I have a x6570 All
I have a x6570 All IN one, I had Recently changed from Windows XP to Windows 7 Since then I have Huge PDF files, I do...
I need the two output cables or cords located in
I need the two output cables or cords located in the back of the Lexmark x83
I am trying to reinstall
I am trying to reinstall my Lexmark x83 printer but when the page where the word install should be is blank. all other...
paper keeps jamming in my lexmark x83. It will
paper keeps jamming in my lexmark x83. It will start to feed them jam. rollers will tumble, then stop.
Our lexmark is not printing correct color and
Our lexmark is not printing correct color and skips parts of printing on lines and doesn't start at the top of a...
Upload a manual for Lexmark X83 All-In-One InkJet Printer
Specifications
TopKey Features
Full Product Name:Lexmark X83 All-In-One InkJet Printer
Type:All-in-One
Technology (Detailed):Inkjet
Max Resolution (Color):2400 x 1200 dpi
Black Print Speed:12 ppm
Output Type:Color Printer
Max Resolution (BW):2400 x 1200 dpi
Color Print Speed:6 ppm
Technical Features
Form Factor:Desktop
Monthly Duty Cycle:1,000 - 9,999 (Individual)
Media
Total Media Capacity:100 Sheets
Multifunction Features
Copying Speed (Black):10 ppm
Scanning Features
Scanner Type:Flatbed Scanner
Memory
Installed RAM:8.25 MB
Warranty
Warranty:1 Year
Dimensions
Depth:14.18 in.
Height:10.64 in.
Width:18.12 in.
Weight:14.99 lb.
What's your problem?
Fix-O-Meter
28,132
28,132 people have viewed this product
- 352 people asked about this product.
- 171 people found solutions for this product.
- 3 people have added this product.
How to resolve...
Getting help...
How To Reset...
