20 Most Recent
Lexmark Z815 InkJet Printer Questions & Answers
Is there a drive for x1200 windows 7
There isn't a Windows 7 specific driver for this model, but the Windows XP driver should work for you. You can find it at the following link:
http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_Z815&segment=SUPPORT&userlocale=EN_US&frompage=null#3
I have a lexmark z815 printer connected via usb to
the easy way out it is to upgrade the desktop to windows xp....I believe that no matter how week is the desktop ..xp it will install on it ...I installed once on a P3 with only 128 M ram and a 1200 CPU...so ..if you have at least 256M ram it will work and there is no need to loose any data either cause you can move them into another partition and format only C ...
Lexmark Z815
Make sure you install the printer drivers before connecting the printer. It also might be a cord or port problem-try a different cable and/or different usb port.
Wifi light is orange
The colors of the WiFi indicator light show the network status of the printer.
- Off means one of the following:
- The printer is turned off or is powering up.
- The printer is not connected to a wireless network and in power saver mode. In power saver mode, the power light pulses on and off.
- The printer is connected to an ethernet network. Refer to the Quick Reference Guide to find out if your printer has ethernet capability.
- Solid orange means one of the following:
- The printer has not yet been configured for a wireless network.
- The printer is configured for an ad hoc connection, but it is not currently communicating with another ad hoc device.
- Blinking orange on the WiFi light means one of the following:
- The printer is out of the range of the wireless access point (wireless router).
- The printer is trying to communicate with the wireless access point but the wireless point is turned off or not working properly.
- Either the configured printer of the wireless access point has been turned off and back on, or the printer is trying to establish communications with the network.
- The wireless settings of the printer may no longer be valid.
- Green means that the printer is connected to a wireless network and is ready for use.
