20 Most Recent Lexmark T644dtn Printer Questions & Answers
I'm assuming you mean the maintaince counters... Turn off the printer. Press and hold the check and right arrow buttons on the front of the printer
Turn on the printer. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. Select Reset Maintenance Count from the Configuration menu. The message Reset Maint Cnt=Reset displays momentarily. Press Check to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Lexmark T644dtn... | Answered on May 11, 2012
1. Turn off the printer. 2. Press and hold (check) and .(right arrow). 3. Turn on the printer. 4. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. 5. Select Reset Maintenance Count from the Configuration menu. 6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Lexmark T644dtn... | Answered on Jan 26, 2009
843.01 = Service Scanner—flatbed mechanical failure.
Basically the manual says to check the ribbon cables inside the scanner and the shafts that the motor runs on.
Lexmark T644dtn... | Answered on Oct 09, 2008
Leading cause of paper jams or misfeed is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Lexmark T Office... | Answered on Feb 09, 2012
Popular Tags
14 questions posted
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
T Lexmark
  • T Lexmark
Most Popular Question
setting print count lexmark t644
  • Office Equipment & Supplies
