20 Most Recent Lexmark JetPrinter Z605 Color InkJet Printer Questions & Answers
Hi.
Download the driver, based on ur OS.
For Windows XP -- Click-> Download Driver
1.For Xp after u click on "Download Driver" u will get a page where u have to type the verification which is displayed in the page, then click download.
For Windows 9x/NT/200 --Click-> Download Driver
For 9x/NT/2000 , just click on "Download Driver" you will get the files.
I would appreciate if u provide a feedback.
Thank You
Riz
Lexmark... | Answered on Jan 07, 2014
Go to "Lexmark solution center", then go to maintenance, then "install new cartridges".Check "No, this is new" option on cartridges and ink level will reset.
Lexmark... | Answered on Nov 02, 2012
Please contact Lexmark Technical Support Center for assistance.
Lexmark... | Answered on Sep 13, 2011
Please visit the Lexmark website to download and install the Lexmark Z605 Printer Driver on your computer. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
Lexmark... | Answered on Sep 04, 2011
Try downloading the Vista driver. Make sure that you select the 32- or 64-bit version, as needed, from http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_Z605&focusedTab=DOWNLOADS#4 . Click on filter to get the correct file. To check the version of Windows that you have, click Start > Control Panel > System and Security > System. If you see x64 after the OS version name, get the 64-bit driver. Otherwise you need the 32-bit driver.
Make sure to disconnect the data cable between the computer and the printer, if you have connected it. Uninstall any problem driver (generic from the Windows OS or a failed Lexmark driver install) before installing the new driver.
If you still have problems, uninstall the driver again. Then use the compatibility mode. Right click on the exe file that you downloaded from Lexmark and choose Properties. Under the Compatibility tab, check the box for "Run this program in the compatibility mode" and select Vista. Then right click again and choose "Run as Administrator".
I hope this helps.
Lexmark... | Answered on Aug 11, 2011
Navigate to the Windows control panel and double click printers and faxes.
The right click on your printer and select properties.
On the box that came up you will see a button that says Print a Test page!
It is found on the bottom right of the box in Windows Xp.
Be sure to rate this session, thumbs up on the right of this solution.
Thanking you
damnor01
Lexmark... | Answered on Mar 19, 2011
Go to Lexmark - United States.
If you need more help post back!
Thumbs and testimonial are welcome!
Lexmark... | Answered on Jan 18, 2011
Use Vista Driver in Windows 7
Good Luck!
Lexmark... | Answered on Jan 14, 2011
It depends on what operating system you have.Click on these lexmark website and locate the download or support tab.
Lexmark... | Answered on Dec 15, 2010
Hi. Thanks for your question.
It seems that i just posted solution to your problem. Please see link below
http://www.fixya.com/support/t7277937-install_software
Thank You for using FixYa
Please click on this link for direct access to drivers & software for your printer. http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_UK&locale=en&productCode=LEXMARK_Z605&page=product&frompage=null#1
Use tabs on the bottom of the screen to get desired software.
Thank you for using FixYa.
Behind the Lexmark Z605 printer, the power supply (rectangular black box) goes into the power supply connector/slot. Refer to the image below.
The power cord then plugs into the power supply from your power outlet in the wall.
If you don't have the power supply, please contact Lexmark technical support for assistance.
Thanks.
Lexmark... | Answered on Dec 12, 2010
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Lexmark... | Answered on Dec 06, 2010
The ink has probably gelled (become solid) in the nozzle. You can try cleaning the print head and cartridges manually. Remove the cartridges from the unit and wipe with a damp paper towel (dampen with water). With the bar code facing you, wipe the bottom of the cartridge horizontally, moving the towel only from left to right. This is where the ink comes out. Continue until it looks clean. Then dab the cartridge on the towel to see if ink comes out.
With a damp cotton swab, also clean the bottom of the shiny piece of metal underneath the contacts at the back of the carrier where the cartridge fits into the printer. This may take multiple swabs.
Reinstall the cartridges and follow the usual procedures. If the cartridge didn't come clean with wiping, you can build a declogging tool with a syringe (no needle) and a very narrow diameter piece of tubing. Cut a short length, place the tubing against the holes in the cartridge nozzle and pull back on the plunger. (This has to be done carefully to avoid damaging the print head.) Look online for information on the syringe and tubing size - it will depend a bit on the cartridge hole size.
Final option - new cartridge.
I hope this helps.
Lexmark... | Answered on Apr 25, 2010
Hi there
Yes it will not work needs the 2 inks in it to work.
Lexmark... | Answered on Feb 14, 2010
If you have not used your printer for a while the phe ink cartridges can dry out, or you have run out of ink. You may need to install new cartidges, you could try cleaning the print heads wich is done with a button on the control panel or from your PC.
Lexmark... | Answered on Dec 27, 2009
its a problem with cartiges circuit change cartidges
Lexmark... | Answered on Dec 07, 2009
go to their website and click on technical support , they might be able to help you out , thanks aj
click here:
http://www1.lexmark.com/products/view/Ink%20&%20Toner/catId=cat10002-category
Lexmark... | Answered on Nov 30, 2009
Lexmark JetPrinter Z605 Color InkJet Printer Logo
Popular Tags
62 questions posted
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Z Lexmark
  • Z Lexmark
Most Popular Question
print test page
  • Office Equipment & Supplies
