Lexmark P315 InkJet Photo Printer
Problems with Lexmark P315 InkJet Photo Printer?
Troubleshooting and Support
Solved Problems for Lexmark P315 InkJet Photo Printer RSS Feed Post a New Problem
RE: Printer not ejecting paper
The problem with my Lexmark 315 isn't that it doesn't print. It starts the procedure as it always does, but then doesn't...
1 Solution
RE DELL ERROR MESSAGE 1203
IVE DONE EVERYTHING THAT THE BOOK SAYS TO DO WHAT ELSE IS THERE
1 Solution
Dell 942 Error 1203
I have inserted a new black ink cartridge in my Dell 942 and have an error 1203. I have tried shutting the printer off...
1 Solution
error code 1203
my printer Lexmark P315 is giving me an error message error1203 see user guide
3 Solutions
Lexmark P315 does not pring
I have the same problem as this person reported but I don't see a solution: hi i need help my printer not working.i put...
1 Solution
paper jam
As soon as I put the printrer in print picture mode it comes up with paper jam.Any help wouldp be helpful...
1 Solution
printer connection to dell computer
How do you connect the printer for photos to the dell computer
1 Solution
Unsolved Support Problems
Unsolved Problems for Lexmark P315 InkJet Photo Printer RSS Feed Post a New Problem
Broken cog in Lexmark P315 needs replacing
Hello, I have a Lexmark P315 which usually messes up the bottom of every print. I have found that a cog is cracked, and...
Post a Solution
Lexmark Printer model P315. Handbook Ref...
Can I use Cartridge No. 35 in my P315 Printer
Post a Solution
lexmark p315 photo printer
hi my lexmark p315 is saying problem reading card please check card is not damaged i have tried several and theyre not...
Post a Solution
paper won't feed in printer....
it will take the paper part way into the printer then it won't finish loading the paper to print the picture, but will...
Post a Solution
lexmark p350
my photo printer is saying cartridge error, i used it 2 days ago and it worked fine i have just put it on and it said...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
TypeDigital Photo
Technology (Detailed)Thermal Inkjet
Max Resolution (Color)4800 x 1200 dpi
Output TypeColor Printer
Max Resolution (BW)1200 x 1200 dpi
Color Print Speed42 sec/page
Technical Features
Form FactorPortable
Connectivity TechnologyUSB 1.1
Monthly Duty Cycle999 and less (Low Output)
Monthly Duty Volume125 Pages
Status PanelColor LCD
Memory Card CompatibilityMultimedia Card · Compact Flash Type I · Memory Stick · SmartMedia · Secure Digital (SD) · xD Picture Card · Compact Flash Type II · Memory Stick Pro · Memory Stick DUO
Direct Printing CapabilityPrint Photos Without a PC
Media
Media TypePhoto Paper
Max Media Size102 x 152 mm
Total Media Capacity25 pages
Memory
Installed RAM32 MB
Warranty
Warranty1 Year
Dimensions
Depth8.3 in.
Height5.6 in.
Width10.8 in.
Weight7 lb.
Lexmark Contact Information
Main support number1-800-332-4120
Sponsored Links
Loading problems.
Top Experts
Ask Me
lilacgerr Wiz
45 solutions
Ask Me
JackHeath Guru
9 solutions
Ask Me
coachb Wiz
4 solutions
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
