20 Most Recent Plantronics Savi W740 83542-01 Dect head Questions & Answers
How do I connect phone to plantronics
hi June, I assume you are using a Plantronics wireless headphone? ensure your phone is on and Bluetooth is switched on in your phone settings. hold the button on the headphone until the light starts flashing, if this does not happen ensure the headphone is charged. in Bluetooth options on your phone ensure your phone is set to "can be seen by other devices" and then use "scan devices" to find your headphone, if you see Plantronics in the list select it and press "pairing" this will then connect the headset to the phone. once paired, everytime your headset is on and Bluetooth is on, you need to just press the button on the headset and it will automatically connect to your phone.(as long as the headset name is not deleted from the Bluetooth list) If your phone does not show in the headset in the Bluetooth list, keep the phone scanning and press the button on the headset to start the light flashing this is now causing the headset to search for the phone. once the headset shows in the phone list do as above. I hope this was useful.
3/4/2015 4:34:45 PM • Plantronics... • Answered on Mar 04, 2015
0answers
Peavey 6505+ NO BASS FREQUENCY EQ
HI,
Switch your amp on and leave it in the stand-by mode, you see tubes glowing.
Than you can pull another tube (same type) out of the amplifier and put it in those sockets. If they are also not glowing, there must be a wiring problem.
It very strange that there are two tubes not glowing.
Give it a try, you can do it yourself.
Reagrds Gerard
8/13/2009 1:53:59 PM • Plantronics... • Answered on Aug 13, 2009
2answers
Cannot pair voyager 510 with
1. Select the Settings icon
2. Select General
3. Go to the bottom and select Reset
4. select Reset All Settings (Warning! This will reset everything on the General page)
you can, try pairing your headset with a friends phone just to makesure it works at all. Also, it doesn’t matter if the WiFi is on or offwith the iPhone,they use two different frequencies.
also ensure if u ve tried this
  • Turn on your Bluetooth headset.
  • From the Apple menu, select System Preferences.
  • Click the Bluetooth icon. Click the Devices tab.
  • Select your Bluetooth headset (it should be displayed in Bluetoothdevices; give that a moment to show up and name itself properly).
  • Click the "Set Up New Device" button.
  • Follow the Bluetooth setup assistant instructions for your headset.
    • Select "headset" when the assistant asks what type of device.
    • Have the manual for your Bluetooth headset handy. At some point,you will need to enter the passkey for your headset into the Bluetoothsetup assistant.
    and also
  • Click the Settings tab.
  • Check the Discoverable checkbox and the "Show Bluetooth status inthe menu bar" checkbox. (Later, you can turn Bluetooth on by going tothe Bluetooth status in the menu bar.)
  • Click the "Turn Bluetooth On" button.
  • Close System Preferences.
  • if both the above methods doesnt work....
    Download, install, and run the Apple Bluetooth Firmware Updater.
    • Download the Apple Bluetooth Firmware Updater, version 2
    • Double-click the BluetoothFWUpdate1.2.dmg file that you justdownloaded. A Finder window for Bluetooth Firmware Updater 1.2 opens.
    • In the Finder window, double-click theBluetoothFirmwareUpdate1.2.pkg file. The updater will install into theApplications > Utilities folder.
    • Follow the install instructions for the Apple Bluetooth Module Firmware Update.
    • Go to your Applications > Utilities folder. Run Bluetooth Firmware Updater.app.Warning! If you're using a D-Link DBT-120 USB adapter,this will make it Macintosh only! If you used your D-Link DBT-120 USBadapter with a Windows computer, you will no longer be able to do soafter this step.
    if all the above method methods fail and if u tested ur voyager and found it works on another mac.... its time to call apple......
    good luck
    thank you for using fixya...
    have a nice day.....
    7/13/2009 1:33:51 AM • Plantronics... • Answered on Jul 13, 2009
    How do I hook up a micrphone to my computer?
    There should be a jack on the CPU cabinet marked with a microphone symbol -- plug it in there.
    4/28/2009 8:32:20 PM • Plantronics... • Answered on Apr 28, 2009
    Never had any problems with
    I tried deleting the headset from the phone device list. Turned the phone off, removed the battery for a min or two and turn everything back on. I now try to pair the headset as if setting it up for the first time and everything is working again.
    12/5/2008 10:17:48 AM • Plantronics... • Answered on Dec 05, 2008
    Vocalizer 3 output checked cables and swapped out. 1300 watt power adaptor lights up. sound indicator light is on but no sound. tried mono and stereo. power adaptor problem?
    If the display is working, you have audio. Check your amplifier. 1300Watt adaptor ... This unit draws a very low power and that is not needed.
    4/24/2024 7:18:55 AM • Audio Players &... • Answered 13 hours ago
    How do I change to degree mode on my porpo YH-2000
    1. Power Off: Turn off the device.
    2. Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
    3. Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
    4. Power Off Again: Turn off the device once more.
    5. Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
    6. Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
    If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
    4/20/2024 8:57:52 PM • Audio Players &... • Answered 3 days ago
    Panasonic SA-PM250 CD stereo system. Tune dab radio sa pm250?
    this model SA rather than SC seems to be a Middle East model. The SC version doesn't have DAB. https://www.google.com/search?q=panasonic+sa-pm250+instruction+manual ..
    4/20/2024 5:59:04 PM • Audio Players &... • Answered on Apr 20, 2024
    Setting time on fmdott085 V398
    All questions need clear 'make model (what it is)' first 3 words. https://www.google.com/search?q=fmdott085+V398 ..
    4/17/2024 4:54:26 PM • Audio Players &... • Answered on Apr 17, 2024
    Openfit Shokz battery replacement?
    Question edited for clarity, typo and CAPS. Question moved from Cars and Trucks category. Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries. How long is the warranty on AfterShokz? While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase. Jan 11, 2019
    How To File A Warranty Claim For Your SHOKZ Headphones
    https://www.google.com/search?q=Openfit+Shokz+battery+replacement ..
    4/16/2024 4:58:24 PM • Audio Players &... • Answered on Apr 16, 2024
    My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
    Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first. But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
    4/16/2024 5:57:29 AM • Audio Players &... • Answered on Apr 16, 2024
    Can f2100 remote work on my dishtv box?
    The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
    4/10/2024 6:11:44 AM • Audio Players &... • Answered on Apr 10, 2024
    Plantronics Savi W740 83542-01 Dect head Logo
    1 questions posted
    Top Plantronics Audio Players & Recorders Experts
     Grubhead
    Grubhead
    SmartAviator
    SmartAviator
    Are you a Plantronics Audio Player and Recorder Expert? Answer questions, earn points and help others
    View Most Popular
    • Plantronics Audio Players & Recorders
    Most Popular Question
    plantronics repair
    • Audio Players & Recorders
