FixYa.com
Lexmark OptraImage 524 Flatbed Scanner
All Products > Lexmark > Scanners
Problems with Lexmark OptraImage 524 Flatbed Scanner?
Search inside Lexmark OptraImage 524 Flatbed Scanner Knowledgebase
Troubleshooting and Support
Solved Problems for Lexmark OptraImage 524 Flatbed Scanner RSS Feed Post a New Problem
The file size of my saved image is too...
The file size of my saved image is too big, i cant work with it, is there anything i can do?
1 Solution
How to test a scanner for color...
How to test a scanner for color registration?
1 Solution
How can i Use a Scanner to Capture Text?
2 Solutions
Which file format is proper to save the...
Which file format is proper to save the scanned image?
1 Solution
How to Connect a Parallel Scanner to a...
How to Connect a Parallel Scanner to a Computer?
1 Solution
My CanoScan D1230U has stopped working
Resentley fter years of use my CanoScan D1230U has stopped working. Everyting was connected properley but it still...
1 Solution
scanner
dont know how to position document during scanning. every position i try cuts off some of the document
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
TypeFlatbed Scanner
InterfaceSCSI-2 Fast (8-bit)
Optical Resolution400 dpi
Max. Resolution (Hardware)400 x 400 dpi
Max. Gray Depth8-Bit (256 Gray Levels)
Technical Features
Form FactorDesktop
Media
Supported Media TypePlain Paper
Media Loading MethodAutoload
Max. Supported Media SizeANSI B (Ledger) (279 x 432 mm)
Dimensions
Depth19.7 in.
Height11.82 in.
Width21.67 in.
Weight61.74 lb.
Lexmark Contact Information
Main support number1-800-332-4120
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
