FixYa.com
ASUS WL-100G 802.11g/b Wireless Adapter
All Products > ASUS > Wireless Adapters
Problems with ASUS WL-100G 802.11g/b Wireless Adapter?
Search inside ASUS WL-100G 802.11g/b Wireless Adapter Knowledgebase
Troubleshooting and Support
Solved Problems for ASUS WL-100G 802.11g/b Wireless Adapter RSS Feed Post a New Problem
getting an ip connection
I tried to getconnected to xbow live but i cant get an ip adress
1 Solution
problem getting IP assigned
Hi all, At startup, my computer doesn't get an IP-address assigned. Signal is perfect, but I don't get IP. The...
5 Solutions
This wireless adapter connects, and then...
I really do not know what has happened to this adapter that has worked perfectly until today. Every time I start up my...
1 Solution
Trouble connecting to 16bit WEP network
I am using an IBMR50e laptop, running Windows XP professional. As my laptop did not come with built in wireless, I am...
1 Solution
Using G630 but get "network cable...
I have the DLink G630 C2 with latest drivers installed on Windows 2000. It used to work then all of a sudden it stopped...
1 Solution
Wireless-G LinkSys Model WAP54G random...
I have 30 computers hooked up to this system. Each computer has a separate external wireless card plugged into the USB...
2 Solutions
Cant get it to work
They forgot the cd for install and went to the 2 wire website and downloaded the drivers. It will not connect. Also says...
Post a Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Form FactorExpansion Card
Interface CompatibilityPC Card (Cardbus)
StandardIEEE 802.11g/b
Wireless
802.11b Data Rates11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps
802.11g Data Rates54 Mbps, 48 Mbps, 36 Mbps, 24 Mbps, 28 Mbps, 12 Mbps, 9 Mbps, 6 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps
802.11b/g Channels North America11
802.11b/g Channels Europe13
802.11b/g Channels Japan14
ModulationDSSS, OFDM, CCK, QPSK, BPSK, DBPSK, DQPSK, 16QAM, 64QAM
802.11b/g Indoor Range40 meter
802.11b/g Outdoor Range310 meter
Security
WEP Encryption40 bit (=64 bit), 128 bit
SecurityWEP, WPA, TKIP, AES, 802.1x
Other Features
Package Qty.1
Operating Frequency2.4 GHz
Operating Voltage3.3 Volt
Dimensions
Depth2.13 in.
Height1.4 in.
Width4.53 in.
Weight1.76 oz.
Warranty
Warranty1 Year
Supported Models
wl100g, WL100GDLX
ASUS Contact Information
Main support number502-995-0883 (select option 3)
Support FAX502-933-8713
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
